Suggested standard for LOCK's — Parallax Forums
Bill HenningBill Henning Posts: 6,445
edited 2011-05-11 17:29 in Propeller 1
I suggest the following standard for using LOCKs to manage access to critical resources.
The reason for specifying lock numbers is to avoid having to negotiate which lock is used for which function in every driver and application.
Lock 0: XMM memory access lock (to allow multiple clients to one XMM solution)
Lock 1: SPI multiplexer access lock (to allow multiple clients to share a multiplexed SPI bus)
Lock 2: Filesystem lock (to allow multiple clients to access a file system)
Lock 3: Network lock (to allow multiple clients to share a network layer)
Lock 4-7: user application locks
The reasoning behind this allocation is:
Lock 0: XMM is the most basic extended resource, and parallel solutions are the highest bandwidth producer/consumer in expanded Prop configurations. I've been using this lock on Morpheus for years, sharing access between refreshing the display and updating the display quite nicely.
Lock 1: SPI multiplexers are here to stay. PropCade and C3 both use them, as do many future boards. The precise multiplexer scheme may vary between boards, but all of them need to manage access to multiple SPI peripherals by potentially multiple client cogs. This will allow safe sharing.
Lock 2: Filesystem lock - Kye's nice new file system driver allows multiple simultaneous open files, so will other future file systems.
Lock 3: Networking lock - for future use
It is important to statically allocate locks so that all the code running on Props can easily use them. Failing static allocation, a "locks.spin" could be used to export "lock#xmm lock#spi lock#fs lock#net" - but I personally (in this case) strongly prefer the static allocation of locks for these purposes.
  • KyeKye Posts: 2,200
    edited 2011-05-11 07:32
    Um, SPIN let's locks be given out dynamically. If you want to coordinate locks you can just add methods in the start functions of code so that they are given the lock number they need to work with before hand.
    edited 2011-05-11 07:40
    This approach saves memory for all the cogs accessing the locks; XMM and SPI mux at least are so fundemental that having pre-defined locks for them makes sense.
    It is also MUCH easier to document for new users... ie
    "Use lock 0 to get exclusive access to external memory, and lock 1 to get exclusive access to SPI devices"
    than
    "if you want to get exclusive access to memory, your main program must do memlock := newlock, then you must pass the memlock variable to every client cog that needs to access xmm. To pass memlock, you have to write it into a parameter block, whose handle you pass to the client". (same for SPI, wrong newlock syntax, I know)
    edited 2011-05-11 07:48
    I agree with Kye. Locks should be assigned dynamically for the same reason we use cognew instead of coginit. Regardless of the stated "advantages", a standard lock assignment is neither necessary nor desirable.
    edited 2011-05-11 07:57
    I vote for dynamically assigned locks. Each object can save it's lock number as a DAT variable and there's normally no reason to know the lock number outside of the object.
    edited 2011-05-11 08:22
    Phil,
    I have a tremendous amount of respect for your knowledge and skills, and am very appreciative of all the help you give on the forums - but
    I respectfully disagree with your double quoting "advantages" - those advantages are quite real due to the limited resources of a 32KB prop, "big system" and "computer science" desired features are often at loggerheads with saving memory.
    I am well aware that modern CS education is focused on readability and flexibility, but I am afraid that has lost sight of embedded systems based on small microcontrolers; also for those new to the propeller it is significantly easier to teach and show examples using fixed lock numbering for the most basic locking.
    I totally agree that in an ideal world, with less limited resources, dynamic allocation is the way to go. I just don't think the Prop is in that world.
    The good news is that people who want to use dynamic allocation can of course do so :-) ... and those that want fixed locks can do so as well.
    edited 2011-05-11 08:37
    Bill, your proposal might save 8 bytes of storage for lock numbers, but the resulting burden on user code to dynamically allocate locks 4 though 7 would probably use more than 8 bytes. I suppose all programs could perform four dummy cognews at the beginning to skip over locks 0 through 3, but it makes almost no sense to me.
    edited 2011-05-11 08:42
    Sorry, Bill. I put "advantages" in quotes because I felt that they did not outweigh those of dynamic allocation, not because I thought they were not real. There will be those who subvert the lock system to gain a few bytes of memory as a last resort when memory is dear, and that might be okay, given no other alternatives. I just don't think the practice should be "standardized", since it encourages a bad habit in other cases where it isn't necessary. Most importantly, objects contributed to the OBEX should always be lock-number- and cog-number-agnostic. If someone wants to change the way a downloaded OBEX object uses locks, in order to save memory, that's their privilege.
    edited 2011-05-11 08:50
    David, I wish it was only 8 bytes.
    Main code:
    OBJ
       client1 : "some_client_cog"
       client2 : "some_client_cog"
       client3 : "some_client_cog"
       client4 : "some_client_cog"
    VAR
      long xmm_lock, spi_lock, fs_lock, net_lock
    PUB main
    ' error checking code omitted for clarity
      xmm_lock := locknew
      spi_lock    := locknew
      fs_lock      :=  locknew
      net_lock    := locknew
      client1.start(@xmm_lock {, other parameters})
      client2.start(@xmm_lock {, other parameters})
      client3.start(@xmm_lock {, other parameters})
      client4.start(@xmm_lock {, other parameters})
    Now the clients need code for picking up all four locks, storing them etc
    At a guess, 10-20 longs overhead per client, so 40-80 longs / 160-320 bytes for the app: 0.5%-1% of the props memory just to be dynamic
    Notes:
    - a little could be saved by packing the lock id's four per long, but that's also against readability, and still needs unpacking in client
    - a more readable "client1.start(@xmm_lock,@spi_lock {, other parameters} would use even more memory
    - I have several applications that share an xmm lock with six cogs that need arbitrated xmm access
    edited 2011-05-11 08:56
    There's no reason for the main program to store the lock numbers. Only the client code needs to know it's own lock number.
    edited 2011-05-11 08:58
    No worries Phil, I totally understand your point, and agree with it in almost all circumstances...
    Dave,
    How is it going to pass it to multiple clients without storing it first?
    Dave Hein wrote: »
    There's no reason for the main program to store the lock numbers. Only the client code needs to know.
    edited 2011-05-11 09:06
    Dave Hein wrote: »
    In Spin, the start function should be called once, even if you have multiple instances of the object. The instance-specific variable are stored as VAR variables.
    edited 2011-05-11 09:13
    Dave,
    Here is one of my applications that shares the xmm lock:
    2x vga_reader - must be started twice, on two cogs, with some parameters different
    1x gpu_cog - started once, different object/cog
    2x sprite_engine - started twice, needs some different parameters launches worker cogs based on parameters
    That's five cogs that need access to the same lock -> lock number must be stored in the main code, or be static
    - vga_reader cogs refresh scan line buffers from the page being displayed
    - gpu_cog draws onto either displayed or next to be displayed page :)
    - sprite engine draws onto the next to be displayed page
    Another application I am working on has:
    2x vga reader cogs
    1x gpu cog
    2+ XLMM cogs
    Again, all need access to the xmm lock
    edited 2011-05-11 09:24
    The lock should be obtained and returned by the driver object that requires it, not by the program that starts it. If the driver controls only a single resource (e.g. SPI using one set of pins), it can store the lock in a class variable, viz:
    PUB start
      ifnot (mylock)
        mylock := locknew + 1
        ... other start stuff...
      return mylock - 1
    DAT
    mylock byte 0
    The host program can then store the driver's lock in a byte variable for later use.
    Better still, higher-level methods in the driver itself can do the locking and unlocking, without the host having to know the lock number.
    edited 2011-05-11 09:44
    I use XMM and SPI locks for locking hardware (xmm bus, spi bus) so multiple cogs can use it directly... so all the clients must share a single lock per bus, and as there is not a single driver, they have to somehow agree on the lock, either by the master allocating it dynamically, or having it statically allocated.
    edited 2011-05-11 09:53
    When you say there is not a single driver, you mean there are multiple instances of the same driver, right?
    edited 2011-05-11 10:01
    No - I mean each client cog gets exclusive access to the bus hardware - ie pins used for XMM, pins used for SPI. Basically I am using them for hardware bus locking for multiple masters.
    I needed to do it this way to get the flexibility and speed for the external frame buffer access and GPU / sprite access for XMM, and for arbitrary SPI device support for SPI.
    I realize this is not the approach for everyone; and to be compatible with locknew, I will locknew lock 0 & 1 for my purposes, and let other client apps use locknew as usual.
    edited 2011-05-11 10:10
    In that case, for your SPI bus, for example, I would create an SPI "driver" that does nothing but serve as a lock assigner, as I outlined above. That would eliminate any need for the top-level object to mess with that detail. It helps to keep things compartmentalized in an object-oriented way.
    The danger you (or someone who uses your objects) might encounter with a static assignment is having locks 0 and 1 preempted by another object that starts ahead of your own, using locknew.
    edited 2011-05-11 10:36
    I think that we will have to agree to disagree :-)
    While conceptually nice, a lock assigner wastes a cog.
    I agree about the danger; which can be averted by using locknew in the main code to reserve locks 0&1 (which I will start doing)
    I respect people not wanting to statically allocate, so I will locknew 0&1 at the start of my main object - this way I can "statically" use them, yet be compatible with everyone else.
    I know that I am not using it in the nicest CS way; however I am willing to sacrifice some niceness for speed and memory savings in this low level case.
    The purpose of this thread was to avoid that danger, which as a result of this discussion is now taken care of, by my using my main code to pre-allocate lock 0 & 1 for my xmm and spi bus hardware locks.
  • ericballericball Posts: 774
    edited 2011-05-11 10:51
    Hmm... most drivers have SPIN initialization code which invokes the cognew, then interface SPIN code which provide the I/O functions used by other apps. Why not invoke the locknew in the initialization code and then the necessary locking logic in the interface code? For cog to cog applications, the lock number could be stored in the global variables along with buffer pointers etc.
    The problem with the static lock number is then the user applications have to handle the case where locknew returns one of the defined lock values.
    edited 2011-05-11 11:03
    I agree... this can be handled by having the main app locknew 0 & 1, so other apps can't get them by accident
    This is the approach I will be taking in the next rev of my internal apps.
    ericball wrote: »
    edited 2011-05-11 11:08
    The lock assigner would be written in Spin. You don't need an extra cog for that.
    edited 2011-05-11 11:14
    ericball wrote: »
    This leads me to a question that is OT for this thread, but maybe with some guidance on an appropriate title I could start a new thread...
    The question is, is there an "accepted" format for creating objects and drivers that are NOT dependent on running from SPIN? It seems that with the push for C and other non-Spin languages on the prop that objects and drivers will be needed that do not have a dependency on SPIN.
    I know I've seen some threads where Bill has discussed comms via mailboxes, just wondering if there is anything formalized.
    C.W.
    edited 2011-05-11 11:48
    I can see cases where the driver needs to be distributed and doesn't exist in a single chunk of centralized code, such as different PASM and Spin cogs using the same resource. In that case, the solution is to use a mailbox located in a rendezvous area in hub RAM. The value of the lock should be stored with the mailbox. That's the technique I use in Spinix, where various processes (cogs) need to talk to the console or to the system kernel. I really don't think there is that much overhead in dynamically allocating a lock and saving it's value in hub RAM.
    I would like to see a stand method for doing mailboxes. This would make it easier to develop code that could interwork with other drivers. Another issue that concerns me is that 8 locks may not be enough for some applications. There should be a way to extend the number of locks by implementing software locks. Perhaps one of the hardward locks could be used to add additional software locks.
    edited 2011-05-11 12:13
    I've did this myself once in a case where I needed more than one lock but didn't want to monopolize the Propeller's hardware lock supply. Basically it involves using one hardware lock as a master lock, along with however many software slave locks are required.
    edited 2011-05-11 12:44
    Phil:
    Agreed, and I intend to pre-allocate 0&1 in my startup code for my evil hardware purposes :)
    CW:
    I "standardized" on a four-long mailbox, with the first long being the command (sometimes encoding some data), second being a destination pointer, third source pointer, fourth a count - however for some drivers I use the longs differently... and sometimes I use more than 4 longs. Cavet Emptor.
    Dave:
    Phil's followup is a great way of getting additional locks for resources that are not extremely time critical - one "multiplex lock" could easily handle many individual slower locks.
    Phil:
    The master lock / soft lock approach is a very good one, and works well.
    edited 2011-05-11 13:25
    You can hardwire lock numbers by requiring that the main program start up drivers in the correct order. The driver should still use locknew to allocate the lock, but it should return an error if it didn't get the expected lock number. That way, the developer will know immediately what is wrong when he tries to run two drivers that are both hardwired to the same lock number. Otherwise, it could take hours or days to figure out what the problem is.
    There would be a problem running a driver that requires lock number 0 under SpinSim. SpinSim implements an implicit locknew when it performs a boot, and the lock number is saved in a memory-mapped mailbox location. This lock is used for the conio and fileio system services. Anything running under SpinSim would have a problem if it required lock number 0. Since SpinSim doesn't support pin I/O (except for serial on P31 and P30) it's doubtful that it would be used to run hardware drivers. However, I have tested some memory caching code on SpinSim.
    edited 2011-05-11 13:31
    That's exactly what I will do... but I will check and make sure I only grab 0&1
    Dave Hein wrote: »
    edited 2011-05-11 13:45
    Dave's proposal seems like a reasonable compromise.
  • RossHRossH Posts: 5,639
    edited 2011-05-11 16:30
    Yes, this is what Catalina does in the multithreaded version of the kernel. Since you can have hundreds of C threads executing on each of the 8 cogs, I (potentially) needed many more than the 8 physical locks. So I added the ability to create arbitrary sized "pools" of virtual locks. Each virtual lock in the pool works much like a physical lock. Access to each pool is managed by one physical lock. Seems to work quite well (although perhaps the efficiency could be improved a little).
    Ross.
