Why would a cap in a router run very hot
I found a pop up cap in the router a few month ago and today I found the same cap very very warm almost
to hot to touch but the router still works the supply voltage is 12,40 when the router is hook up the supply voltage is 11.90 replacement switching power supply
I found one in the switching power supply today pop up and one transistor fryed in it output voltage was rated at 12 volts @ 1 amp out voltage was 8.7 volts no load the router still working but real flake
What is the voltage rating on the cap? Sometimes they run the cap right at the limit to save on costs. Then you throw away the unit and buy another one. Perfect inbuilt obsolescence!
Hopefully you have got to this in time and can replace the component before it gets so fried that you can't read the writing on the side.
its not the Voltage . Its the current.. the charge discharge cycteing at 40+ KHz for a SMPS is appoching RF and casues Local heating from a wound cap like most electrolitics are ..
I have the same issue with the rail that powers the HV inverters in LCD desktop screens // 90% of the time its the 12V rail caps .
One time I mesured allmost 20A peak on the cap charge cycles . ( shunt and a O scope ) on one Viewsonic set
Peter
http://forums.parallax.com/showthread.php?126804-Bad-capacitors-Samsung-LCD-TVs&highlight=samsung
I've seen this before but can't tell if it is connected.
Smart cookies use a few smaller caps in parallal and use a few diff valuies .
1µF for fast transients 10 for slower stuff and a few 100s or so for the bulk of the filtering.
as we know a 1µF carmic cap has a Very fast Dv/Dt response rate On the whole in comparison to normal electrolytics . so use them for the fast stuff . If you have voltage potential from DV/DT then there is current flow .. and that along with Mr Ohm = heat . so if we can lower the Ω then we can have less heal loss . and volla our problem is solved .
I have seen the insides of Really good SMPS lab supplys and what not and they all use the stepped cap design .
Peter
I am going to replace this again with two caps instead of one and hope this will help
I also found three chips in this router that run very very warm also most to warm to touch
This router has always run very warm from the first day that I bought this
