What two values for VGA R-2R resistor ladder?
This shows that for a 4bit dac I would need five of the 2R and three of the R
Finding a complete r2r array with right values for the prop vga is probably impossible.
This R=200ohm one could be close, it's SIP and I'm looking for SMD
http://www.mouser.com/ProductDetail/Murata/RGSD8L201G/?qs=sGAEpiMZZMvrmc6UYKmaNXFn7JV0JJEYnMFa1MNj5Yc%3d
So for my 12bit-rgb vga I was thinking going with isolated array(s) with a total 15 individual 2R
and a second array of nine individual R
One option would be to get 33 of the 2R and put nine sets of two in parallel to make the R
Attached is some info I gleaned off the interweb while surfing for R2R information.
Bourns and IRC make R2R ladder networks (not sure if they meet your requirements).
3.3 * 75 / (75 + R) = peek volt
As the props output will be closer to 3.0v
So with R=180ohm and R2=360: peek Vout=0.88
But using all 470 ohm (+470s in parallel) probably best
http://mouser.com/search/ProductDetail.aspx?qs=aMbtsk9EOIZKUcUZAgQOww%3D%3D&cm_mmc=findchips
Isn't peek suppose to be 0.7v ?
But Linus made his 0-1v peek, maybe due to blanking level is 350mV that offsets it?
Or that some monitors can adjust for it?
http://www.linusakesson.net/hardware/beagleboard/vga.php
