Calcium Measurement — Parallax Forums
Calcium Measurement
RS_JimRS_Jim Posts: 1,777
edited 2011-05-11 08:39 in Accessories
Has anyone seen an inexpensive way to measure disolved calcium in water? How about PH sensing?
Jim
  • LeonLeon Posts: 7,620
    edited 2011-05-09 06:19
    For testing water "hardness"? I don't think that pH will work, because of all the other stuff that gets into water.
  • RS_JimRS_Jim Posts: 1,777
    edited 2011-05-10 05:52
    Actually, I need two sensors, 1 for hardness and 1 for PH.
    Jim
    edited 2011-05-10 17:58
    Is hardness a function of only calcium, or does it include other minerals too? Do you need to know specifically the amount of calcium, or just whether the laundry will be soapy enough?
    edited 2011-05-10 18:03
    It's mainly the amount of calcium, IIRC.
    edited 2011-05-10 19:06
    I think Fe and Mg also play into the hardness equation. Also, aluminum. (Leon, that's aluminium to you. )
    edited 2011-05-11 06:05
    When I did a search for hardness testing, I found lab instrument probes that would measure hardness, but very expensive. I know that other minerals can come into the picture in hardness testing but I thought that in my case measuring calcium would give me a usable answer. I have seen hardness detection built into water softeners but don't know what technology they use.
    Jim
    edited 2011-05-11 06:19
    RS_Jim wrote: »
    ...I have seen hardness detection built into water softeners but don't know what technology they use.
    You might take a look at page 14 of this manual.. It's fairly complex and probably not what you're hoping for, but my guess is that if they "must" use a system like this, then there's no cheap, easy way to do it, at least not with any good accuracy.
    Thanks, I checked out the link and yes that is probably overkill for what I am looking for. I guess I will continue to search!
    Jim
