Issues with prop to prom communication with xbee
Hello
i have 2 propeller boards and 2 xbees i am trying to send data from 1 xbee to the other to ensure communication but my code does not seem to be working. if someone has some code that works or can tell me what i am doing wrong in my code would be awesome.
CON
_clkmode = xtal1 + pll16x ' use crystal x 16
_xinfreq = 5_000_000 ' 5 MHz cyrstal (sys clock = 80 MHz)
LCD_PIN = 0 ' for Parallax 4x20 serial LCD on P0
LCD_BAUD = 19_200
LCD_LINES = 4
' Set pins and Baud rate for XBee comms
XB_Rx = 1 ' XBee DOUT
XB_Tx = 2 ' XBee DIN
XB_Baud = 9600
CR = 13 ' Carriage Return value
Var
word stack[50]
OBJ
lcd : "debug_lcd"
XB : "FullDuplexSerial"
DXB : "XBee_Object"
PUB main(value) | Counter
XB.start(XB_Rx, XB_Tx, 0, XB_Baud) ' Initialize comms for XBee
Delay (1000) ' one second delay
if lcd.init(LCD_PIN, LCD_BAUD, LCD_LINES) ' start lcd
lcd.cursor(0) ' cursor off
lcd.backLight(true) ' backlight on (if available)
lcd.custom(0, @Bullet) ' create custom character 0
lcd.cls ' clear the lcd
lcd.str(string("Sensor Node", 13))
lcd.putc(0) ' display custom bullet character
lcd.str(string(" RX", 13))
lcd.putc(0)
lcd.str(string(" TX", 13))
repeat
repeat Counter from 1 to 2000 ' count up to 20
' Send to Base
xb.dec(Counter) ' send decimal value
updateLcd(Counter)
' Delay (1000) ' one second delay
' lets wait for some data
Value := DXB.RxDec ' Wait for and accept decimal value
'DXB.Dec(Value) ' Send value back to base
updateLcd(value)
PRI updateLcd(value)
lcd.gotoxy(12, 1)
lcd.decf(value, 8) ' print right-justified decimal value
lcd.gotoxy(12, 2)
lcd.decf(value, 8) ' print indicated (with $) hex
' lcd.gotoxy(7, 3)
'lcd.ibin(value, 12) ' print indicated (with %) binary
pub Delay(mS) ' Delay in milliseconds
waitcnt(clkfreq / 1000 * mS + cnt)
DAT
Bullet byte $00, $04, $0E, $1F, $0E, $04, $00, $00
