Ping sensor with Pic 16f877a problem!! — Parallax Forums
ricorimtoricorimto Posts: 1
edited 2011-05-08 15:41 in Accessories
hello,
i 've connected ping sensor with pic 16f877a and one servo , trying to make the servo stops every time the ping detects objects, here's the code i'm using with picbasic :
main:
i var byte
distance var byte
cms var byte
trisb=0
run:
servo:
for i =0 to 174
pulsout 7,170
pause 20
next i
gosub getdistance
if cms <40 then stopservo
goto servo
getdistance:
low 1
pulsout 1,1
low 1
pulsin 1,1,distance
distance=distance/2
cms=distance*9
return
stopservo:
pulsout 7,150
pause 5000
goto run
end
please help!!!
    From the look of it it should stop for about 5 seconds, however your 'stop servo' routine need to be updated at about 50Hz, so the stop servo section that reads...
    stopservo:
    pulsout 7,150
    pause 5000
    goto run
    might be better off looking something like this...
    stopservo:
    for i =0 to 174
    pulsout 7,150
    pause 20
    next i
    pause 5000
    goto run
    ...Also, you might want to increase cms to a WORD value
    ...similar to how you have it in the regular servo routine.
