Stepper Motoring With The Propeller — Parallax Forums
PJAllenPJAllen BannedPosts: 5,065
edited 2011-05-20 21:22 in Propeller 1
Here's how to run stepper motors with the Propeller.
I used a SpinStamp (The Best!), a ULN2803, and the commonly available Howard Industries 1-19-4200/SM4200 (it's a unipolar).
I've attached a SPIN program and a schematic and, lest any despair, here's a vid of it all.
What's in the OBEX? I don't know and I don't care.
Don't talk - Do!
If you have questions, hit me up.
Keywords: How do I connect stepper motors? How do I drive stepper motors? How fast can I run stepper motors? SPIN code for stepper motors. Stepper motors and the Propeller. How do I interface a stepper motor with the Propeller.
Post Edit -- Found a bug, didn't want to leave bad code. Please see #8's SPIN attachment.
Updated schematic, see post #12.
850 x 573 - 66K
    edited 2011-05-08 10:39
    PJ,
    Good show! That's about as clear and succinct a demo of unipolar stepping as I've seen. Please add some keywords to your post so it will be easy to find down the road when a beginner asks, "How do I ... ?"
    edited 2011-05-08 12:08
    Nicely done PJ!
    And, bonus, no optoisolators!!! :)
    edited 2011-05-11 11:44
    I appreciate your kind attention.
    I didn't declare any stack space, because it hasn't yet become "second nature" for me to do so and I don't have a "good feel for that" either.
    I let my contraption run overnight and saw that it had konked out when I got up this morning, which gave me pause for concern, and after lunch it hit me - Stack[x]
  • JonnyMacJonnyMac Posts: 9,841
    edited 2011-05-11 12:00
    I wrote this a long time ago and would do a better job today, I'm sure, but it does work and lets you control motors with their own cog (no assembly required) so that your main task can do other things. It works with PJ's circuit as well as with push-pull drivers like the L293D.
    -- http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol7/col/NV136.pdf
    edited 2011-05-11 13:41
    So, any guidance on this Stack[ ] deal?
    Maybe I'm missing something.
    Go with whatever, till it seems like it's OK, Stack[100] ought to do it?
    ("Yeah, 120... 121, whatever it takes.")
    edited 2011-05-11 13:48
    There's recursion involved (Main -> wave -> twophase ->halfstep -> wave) so eventually you'll run out of memory for the stack. In your case, you're only using the one cog and the default stack is what that uses. That occupies the space from the end of the program to the end of memory. You only need an explicit stack space declaration if you're using COGNEW or COGINIT to start a Spin program in another cog.
    edited 2011-05-11 16:23
    O-I-C
    Ja, I am being recursive.
    I keep doing that, too. And those RETURNs [eh]. :zombie:
    Life with the Propeller is a PUB crawl. Non?
    PUB Main
      dira [7..0]~~
      [COLOR="blue"]Modes[/COLOR]
    PUB Modes
      repeat
        wave
        twophase
        halfstep
    I'll leave her run and see what happens.
    Post Edit -- That was it. The konking-out never happened the several hours that I'd had it running originally, or I'd turn it off to re-arrange this & that or whatever and back on, so I never knew. Now, I know.
    edited 2011-05-17 07:58
    OK.
    I have things so that I can advance to the disk to any arbitrary position by clicking a pushbutton, "adv/jog"; select that as "home" with a separate pushbutton "ent", and then advance 60deg (using "adv/jog").
    A likely story but for the demo.
    My adv/jog isn't as snappy as I'd like it to be, but fat chance getting anyone to talk about SPIN around this place.
  • Mark_TMark_T Posts: 1,981
    edited 2011-05-17 08:26
    That diagram's wrong - you need to drive the windings in quadrature, so the ABCD phases in order should be brown/red/green/white not brown/green/red/white
    edited 2011-05-17 08:46
    Mark_T,
    Nope. It's 100% accurate.
    If it was "wrong" then it wouldn't work.
    Stepper motors are funny that way.
    I'm half-stepping, it's right or it'd blow chunks.
    I guess you missed the hotlinks to the demos?
    Have a good day.
    edited 2011-05-20 11:29
    Mark_T,
    Your post (#10) has been stuck in my craw like an unbuttered Triscuit.
    My depiction of the stepper motor itself was inaccurate, specifically the colours/names.
    The order of the coils' actuation is BRN, GRN, RED, WHT,...
    Since the center-taps of both windings are tied together, my simply checking the ohms was inadequate to the task. I found the answer that I was looking for that way, but that was a hasty, superficial conclusion.
    I went looking for and found an old N&V article that I'd stashed away ("Build a 3-axis stepper motor controller", Feb '97) and pored over it exhaustively. I got out the ac signal generator and did a lot of probing, voltage and phasing observation.
    Consequently, I have edited my schematic. I have highlighted the corrections (the colours/names of the wires and their relationship to the coil windings.)
    I omitted the original.
    So, now there is harmony between my practice and operation, and the depiction of the stepper diagram.
    Hit me up if you have any questions or substantive comments.
  • SSteveSSteve Posts: 808
    edited 2011-05-20 19:47
    PJ Allen wrote: »
    I think if you tried to get some help writing it in C# there are plenty of people who'd jump in to give advice. :)
    PJ Great. Thats the way. Nice to see a project like that.. Simple.
    BTW We all make mistakes, except for those who don't and they have never done anything :)
