configure the i/o from bs2p40
i dont understand how to use i/o from J2 in bs2p40.
I have tried to call the output with a high 16(A0) but instead returned to the high 0(P0) ..
help please..
help please..
BS2 Syntax Manuel
http://www.parallax.com/Store/Books/BASICStamp/tabid/168/CategoryID/42/List/0/SortField/0/Level/a/ProductID/143/Default.aspx
The BS2P40 uses a serial shift register for the AUX pins
Its well documented in the above Manuel under BS2P40
There is also some special command sets unique to the BS2P40 to easily get access to the AUX pins
I really like this chip when I need a few extra I/O pins
I short little read should have you up and running in no time.
If your still struggling after the read, Just reply back to your post here, And we'll help you figure it out.
If you have a BS2 Pro. Dev. Board the pin-outs are different with the BS2P40 then with other BS2's
Its very confusing if you haven't read the Manuel first.
Have Fun
