I invented my own basic stamp
Thats right....I have developed firmware, just like in a stamp from a BS1 to a BS2P...best of all this firmware of mine with work on Amtel parts...I will call it the Postee...the firmware has all the regulars, pulsout,pause,etc...but includes analog keywords for using built in ADC's...I will make all files on
a open source site soon....just think a stamp clone for less then $5
Sounds interesting but a real stamp is only $10.99.
Rich H
Do keep in mind that this is a Parallax support forum and "advertising" something that competes with Parallax products would be in poor taste.
You can get a PCB for around $3 that you can use to carry any of the more advanced OEM BASIC Stamp chips (based on the SX48 chip) that Parallax sells and build a Stamp module on a budget. With that you can use the regular Stamp development tools and get the same great support on the forum.
http://forums.parallax.com/showthread.php?114299-Carrier-PCB-for-OEM-BS2p40-Stamp-chip.
There are other variants on small BASIC like chips and the PICAXE comes to mind. However, you really need to compare them to the OEM BASIC Stamp chips (plus a resonator and EEPROM which are both inexpensive) to make a fair comparison. When you look at the finished Stamp module that also has the power conditioning/voltage regulation on board in a very small form factor.
Agreed
agreed....I dropped the idea for posting it....too many cry babys
However, you will not publish the source code because you feel that your hard work has not been well received on the forum. I'll paraphrase, the community members that responded are cry babies.
I, for one, am very interested in your work and would much appreciate it if you could find your way to publishing the source.
