Wireless technology - Bluetooth, Blackberry , blueberry, strawberry , Holle Berry?
I want to build a remote accessible / controlled device with all the bells and whistles, for short cool.
What would be the most common off the shelf wireless technology to utilize?
The preliminary spec real time video of reasonable frame rate and resolution ( no video processing reqiured and no HDTV!),
independent ( not dependent!) on Internet wireless technology of any kind,
unlimited number of control channels ( or at least 16 channels) ,
absolutely guaranteed range of 1 mile...
... and controlled by BS2e
Vaclav
Vaclav
There are lots of kind of video these days. Are you talking about analog? If digital, what variety? What kind of control channels?
Absolutely guaranteed range of 1 mile ... What kind of conditions? What kind of weather? What's in the way (is it open space?)
Controlled by a BS2e ... for what? What kind of control?
You may want some kind of multiband solution, maybe one off-the-shelf unit for video (NTSC or PAL) transmission and reception and other off-the-shelf unit for the control, say an xBee Pro with an external antenna.
I need to work on real spec. Looks like 2.4GHz ISM is getting too crowded.
There is plenty of off-the-shelf hardware for 433 MHz, but the range is too short ( 100 meters).
I may opt to modify this hardware for higher frequency (smaller antenna) and longer range.
I need to study Bluetooth technology - it looks promissing.
But it is a start.
Vaclav
Unless you've got a lot of experience at building microwave equipment from scratch, I'd advise against attempting to modify existing hardware for other frequencies. It's not trivial. Signal losses tend to be very high without a great deal of care and dimensions of structures and wiring tend to be critical for performance.
I don't know where you're located, but licensure is also an issue. If you have an amateur radio license, there are all sorts of frequency bands between 433MHz and 2.4GHz that you have access to and at power levels where you can get reliable transmission at the range you're talking about. If not, you can get in trouble.
Reason I am interested in Bluetooth - I like the protocol ability to frequency hop ( just an interesting concept – not sure how practical in my project). And down the line I would like to explore Bluetooth ability to pass the data from one device to another - tandem like - not directly between two end points. I am still learning about Bluetooth and have no idea what is the correct technical term – something about micro cells, not sure.
I am sure using the Bluetooth protocol would be OK on ham band as long as other licensing rules are followed.
Last time I looked in US FCC Part 97 using remote control on ham bands have some specific rules - such as there is no requirement to identify the transmitter while transmitting remote control data and coding is allowed.
It is verboten to transmit coded messages by US hams, of course Morse code is an exception!
Vaclav
I am NOT a fan of those data modues I see on 433 that is smack dab in the middle of a active ham band . 315 and 900 are a way better choice for everyones sake .
Ok here is s issue with BT . as of now I have NOT seen any hams using it aa a link . But be aware some newer HTs and Mobile rigs have BT as a wireless hand mic . so its legal in that sense But as a primary comincations path you may have issues...
and If you do use it Il bet you will have to ID some how . Call the FCC .....
I have yet to see a standard way to use a ID function like there is on a WiFi AP as SSID on BT ..
Peter KG6LSE
you got valid points, however, I do not want to spent my time being on hold with any government agency, including FCC.
I think the ISM frequency usage and rules are pretty clear.
As far as these data modules being in middle of ham band I think their power output should not present a thread to any ham traffic.
Besides, nowadays if your signal is not "10 over nine" “full quieting” nobody will talk to you anyway.
Just to get back to subject - do you know what is a highest ISM frequency in general commercial use?
I found some stuff in 2 GHz ISM.
Eventually I would like to do some video processing and I think the challenge will be to find or convince the processor to keep up with the data.
Vaclav AA7EJ
assuming you are talking about no need for ID I think you are "picking" on the wrong guy . I think Leon is suggesting "5 over 5 over 5" stacked Yagis on 300 foot tower!
Just kidding, Leon.
Back to subject - I think one could implement Bluetooth piconet to pass the message over longer distance. Of course the message delivery time need to be taken into account then.
QRP here ( 100W)
My sorries...
Somewhat off topic, but not that far (re:Transcievers and HAM stuff):
My name has finally appeared in the FCC lookup table yesterday; I've only been waiting since saturday at the local hamfest!
http://wireless2.fcc.gov/UlsApp/UlsSearch/license.jsp?licKey=3286902
I'm currently working on my hardware purchased / setup...
KK
I believe your right. I'm corrious now about it...
KK
please send me more info on this Bluetooth LA. I hate to reinvent the wheel.
Would be nice if I could modify my CB radio to do that.(!)
Vaclav
never mid , here is one candidate http://www.sena.com/products/industrial_bluetooth/esd1000.php
And Leon was right - it only takes an "optional antenna" to get 1000 meters range. But I am from Missouri!
Wonder what would "5 x 5 x 5 " Yagi do.
Is there a stamp for DXCC using Bluetooth?
Per spec - this has an " UART interface ". I assume that means serial *RS232" protocol.
That would easy to control but possible speed bottleneck. I'll keep reading the spec...
One of my favorite sites!
Now this chap only changes the antenna. I can't find the one on about the amplifier, in in any case, this is a "ya got to do both sides" type deal... There's some basic math in the first or second page. Also they state the operating freq, which could be helpful in making the amp. There are also a number of BT amps out on the open market.
KK
That's what Citizens' Band and Family Radio Service walkie talkies were designed for. In the US, there's nothing "outside of the FCC's rule". Even Part 15 (unlicensed low power) stuff have rules that have to be obeyed.
