Fluorescent light bulbs disposal and power saving rant.
The headlines shoould read the economy is booming - some folks are stocking up on light bulbs.
Besides blatant government meddling in consumer affairs I would like to point out that I have not heard anything about disposing these ceramic and mercury containing devices.
Like anything else they will eventually fail.
I recall that disposing of ceramic IC was never satisfactory resolved too.
We do not really care about our future, just present. Let our grandkids figure it out or just ship it somewhere.
The idea of saving electricity does not hold either. We live in greedy world of reversed supply and demand - the less you consume the higher the price so the maker keeps making money.
I sincerely hope the whole idea will blow over just like the New Improved Coke did.
What this got to do with BASIC Stamp? A lot, I cannot see what I am soldering under this blue light.
I don't like gov't meddling and do agree that incandescent should not be banned.
I seem to recall a story indicating that the mercury in modern CFL's is less than the mercury that would be released due to burning coal to produce the difference in electric use between equivalent CFL and incandescent bulbs.
C.W.
for the record I use LEDs in my room ..
Our local Home Improvement stores take them for recycling (Home Depot) for free.
Rich H
http://epa.gov/cfl/cflcleanup-detailed.html
Al
Considering that the amount of mercury in a CFL is about 4 milligrams, I'd say that your link is hysterically overreactive. Link: http://www.energystar.gov/ia/partners/promotions/change_light/downloads/Fact_Sheet_Mercury.pdf
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en549342
I paid $7.99 for a 25W candelabra replacement LED bulb and it was very dim compared to a true 25W bulb plus it failed after just a few months.
I'm sure they will eventually work out the kinks and get the price down, but I don't see them replacing CFL for quite a while.
I haven't really looked, so maybe they exist, but one thing that seems to be needed are well ventilated ceiling fixtures as LED bulbs tend to have external heatsinks that won't do much good in a small enclosures.
C.W.
John Abshier
I prefer regular fluorescent over CFL where possible, as they are cheaper, more efficient, and light up a larger area. Where I would really like to use a CFL is for my front porch light. Incandescents seem to last only a few months. I'm using an X-10 timer to turn it on and off, but it doesn't seem to work right with CFLs. It worked for a while, then the CFL started blinking. So now I'm back to those expensive, energy hungry, always failing incandescents.
- Mark
For X-10 control, you need to use an appliance control unit (on/off control only), and not a light control unit, that can dim the lights. Most CFL bulbs cannot be dimmed and don't work correctly with the light control unit. So this rules out the wall switch type X-10 control units, as they are only for resistive-load lights that can be dimmed.
I managed to burn out a wall-wart power supply (an inductive load) by plugging it into a X-10 light controller. The appliance controllers work much better for that as well
-dan
Cheap CFLs take a long time to come up to full brightness, and they often have a shorter lifetime than the incandescent bulb they replaced. People that throw away a perfectly good incandescent light bulb and replace them with a cheap CFL are wasting money. The better CFLs do last longer, and they have a much shorter turn-on time. I only buy GE CFLs because I know these work well, but I'm sure other known brand name CFLs work fine also.
I think LED lights are the way of the future, and I plan on switching to LEDs when they become cost-effective.
I went to Menard's, a big box home improvement store, last night and found one ceiling light that had a gap all the way around where the glass globe meets the base, it was labelled as being for 2 A19 60W or Equivalent CFL. All the others were just labeled as being for 2 A19 60W. So it looks like the fixture manufactures have some catching up to do.
C.W.
It looks to me , as many things in live, this is not such clear cut and dry issue.
The technology will eventually became reliable and usable.
However, I am convinced that legislating the mandatory usage of this technology now proves again that our legislators need to retire soon and go fish'n.
Got any New Coke?
Vaclav
Unfortunately, I've never seen an X-10 wall switch controller for appliances. I may have to try one of my dimmable CFLs on it. Fortunately, this fixture places the bulb upright, so heat is less of an issue.
I have also considered using a sensor to turn it on and off. There are some new ones for CFLs. But I don't want it burning from dusk to dawn.
- Mark
Appliance Module 2-Pin Grounded
Appliance Module 3-Pin Grounded
