FCC regulations (USA)
I am getting closer, every day, to the production of the MuAmi, as such I have the fallowing question.
What FCC regulations do I have to worry about in order to produce the MuAmi?
If I export to other countries are there any approvals needed from other regulatory commissions?
Thank you all in advance.
http://forums.parallax.com/showthread.php?109903-Rohs-requirements-amp-FCC
http://forums.parallax.com/showthread.php?124449-Best-practices-and-basic-techniques-used-for-short-run-SMT-of-boards (see the last few sentences of my #4 post specifically)
Since the forums won't complete a search for 3 letter criteria (IE: FCC), do a site restricted Google search to find additional threads on FCC. In the Google search box, type in "FCC site:forums.parallax.com"
Many manufacturers join an association that helps them keep up with the compliances they must have. But I have doubts that these always do their job.
The recent European requirement for ROHS was a disaster for most that tried to follow consultants advise on how to comply. Everyone got on a bandwagon of setting up two production lines and separate inventory. Then reality sunk in and nearly everyone that wanted to export globally discarded their non-ROHS line as it is easier to just not have duplicate inventory and proof that components are being kept perfectly separate.
In sum, use your own common sense when you decide what you want to comply with. Following everyone else's can be very costly.
Testing for CE conformity where I used to work wasn't very expensive. We kept the cost down by hiring the facility for a 1/2 day, doing our own preliminary testing, and fixing any problems that arose. The formal testing was then just a formality.
After a bit of research, I have found that, as long as no issues are reported, there is no need to get FCC certification (this will give me the ability to get started [just must make sure that all Faraday shielding is complete]). As to the CE, it appears that may be a problem.
