What is the OS world comming to???
I just found that a certain new version of a well known OS (that shall remain nameless), by a certain well known company (that shall remain nameless), no longer supports standard Game Ports or traditional UART chips for RS232. As such I ask what has the OS world come to that we can no longer rely on drivers for ports that are needed for hundreds of thousands of devices?
May I ask what UART you are using??
Also have you seen a standard Game Port working??
The UART (universal asynchronous receiver/transmitter) is basically the chip that controls traditional serial ports. The reason I ask is some newer machines use an USB adapter internally to give you an externally accessible RS232 port. For more information on UART see:
http://en.wikipedia.org/wiki/UART
Uses serial.sys as the driver, is on IRQ 4
I do, I still buy brand new Game Ports and serial cards (using the traditional UARTS) and every PC compatible has both (it would not be a 'PC/AT' or 'PS/2' compatible with out the UART, and no one wants a USB bottle neck on there game controllers).
But at 480 MBPS .
thats Boat load more bandwith then RS232 Will EVER support .
230kBPS is a Huge order slower around 2000 times slower ..
I Highly doubt that any delay from a USB to serial adapter is going to be a issue
If its fast enough for HD video and many channels of sound its WAY fast enugh for plain jane serial ... or for game ports .
Evin USB 1.1 has Plenty of head room...
Peter
USB is fast enough if you do not have hundreds of high speed devices hooked to it, then it gets so slow that the mouse can become jerky and you can have noticeable delays on the KB (if you use USB for KB/Mouse)
This is why I use PS/2 for KBs and mouses, PCI-X Graphics adapters, PCI Sound Cards, PCI Video Capture cards, LPT printers, pATA HDDs & CDROMS, SCSI 3 CDR/DVDR/RW, etc...
You would be lucky to bus power 20 Mice off USB let alone 100s of devices . 500mA is not a lot of power .
computers change and there is nothing you or I can do anything about it..
but we have one choice .
we can hold on to dead stuff like OS 9 and PPC EiDE and PCI ISA SDRAM ADB PS2 IRDA SCSI FLOPPY . and some day have a rude awakinging that we never upgraded when we should have .
( with the way Vista was made the writing was on the wall for years .. )
Or we can be proactive and not be on the bleeding edge but right next to it and not let this stuff of change slow us down .
bere in mind I used a G4 on OS9 till 08 then the old lady went up in a ball of fire ( no joke) and the next month I had this mini . . now its geting old as its OS 10.5.8 . but I dont have the need to upgrade as its supported as far as apps go . I spent over 5 Grand getting new SW for a entire new platform when the G4 let the smoke out . . had I upgraded to OS X and the apps then in 03 It would have saved me over 3 grand .
Peter
Linux remains the OS that is willing to let the user determine when his hardware is out-dated. And you might look at Free DOS for yet another interesting bit of retro computing.
I am aware that USB only supports 128 devices (127 + host) per bus, I am also aware of the power issues (hence most high end USB being separately powered).
I have long let go of 'Dead tech'. It is not dead if every one still uses it (USB to RS232 is still RS232) there is a reason that all high end mother boards still come with PS/2. Only the low end 'throw away' boards do not have PS/2.
So, the limits of connecting 128 via USB to PC is misleading and generally non issue anyway.
Also, until recently Windoze XP had a real issue starting up USB devices.
And please – do not blame it on old drivers.
XP SP3 apparently fixed the problem.
So before MS abandons serial port they better learn how to operate USB properly.
@PhiPi: While the saying "only old computers have serial ports" is the typical feeling about serial ports, it's actually far from being true. Computers are readily available that have way more than enough horsepower to run Win7 and have serial port(s) onboard. Servers, industrial PCs, "CarPuters", rack mount PCs, gaming PCs, etc, have onboard serial ports.
Windoze is one of the most successful OS shells (it is not an OS [NT (modified MS-OS/2)], or DOS is the OS), that does not make it good (as most who are familiar with it and others can attest). Thus the argument of USB being successful is not a good argument. Yes, MS is on the USB committee, maybe that is the problem with USB.
I have heard and seen news stating that ms and novel will eventualy merger in the next few years and come out with a new OS supporting both *NIX and MS compatability, but both companies seem to not go pulic with the info yet. Oops, was I supposed to say that.:nerd: Maybee thats why MS started a buyback of a ton of their shares last year, they need to make a large purchase.;)
These competing OS's will all have compatibility with each other in the coming weeks/months/years as it has become a required need by the public at large like us, and a bunch of developers having to write code for multiple OS's to support a single product.
if you want to see what might be coming out in the future from MS checkout MS's connect website if you havn't already, you may get an invitation to some new things. Not to mention offering feedback directly to ms staff and developers regarding what you expect from them/their software.
http://www.channelregister.co.uk/2011/03/24/novell_cptn_germany/
Here is a PCI serial card that is supposed to work under Windows 7:
http://www.perle.com/products/serial-parallel-pci-card/SPEED2LE1P-2-port-serial-parallel-pci-card.shtml
Here is a PCI-Express card:
http://www.perle.com/products/pci-express-parallel-card/SPEED1LE1P-Express-1-port-serial-parallel-pci-express-card.shtml
According the Wiki entry here:
Microsoft has stopped supporting the game cards directly in the OS so it moves on to 3rd party for support. Looks like drivers are there for some of the creative sound cards that work with Windows 7. For some devices not having the drivers directly in the Windows OS isn't a big deal. As long at they don't block access to third party drivers and/or going directly at the HW it shouldn't be a problem.
Robert
