regulating a high power heating element with a pulse driven SSR
I am regulating a high power heating element with a pulse driven SSR. I am driving it with a prop driving a 2N3904
for 5 volts (direct didn't work) driving a 90 amp ssr.im only switching it about 10 or 15 times a second with something similar to this
http://cgi.ebay.com/SSR-40-DA-Solid-State-Relay-40A-Output-24-380VAC-/310315296107?pt=LH_DefaultDomain_0&hash=item48403ba56b
with this
CON
_xinfreq = 5_000_000
_clkmode = xtal1 + pll16x
PUB LedOnOff
dira[3] := 1
dira[18] := 1
repeat
outa[3] := 1
outa[18] := 1
waitcnt(clkfreq/12 + cnt)
outa[3] := 0
outa[18] := 0
waitcnt(clkfreq/20 + cnt)
this is usually done with a very expensive thyristor controlled power supply
Im running a test element that draws 20 amps on constant 220 measured with a clipon amp gauge. pulsed with this timing it shows 14 amps. system seems to work great.
Questions how efficient is this ?whats the best frequency how fast could I run this ,(device says 10millisecond turn off time)? how to calculated true RMS voltage/current ,I dont have scope or wattmeter. comments?(beside "Dont electrocute yourself!"
Jim
Riverpottery.com
with this
CON
PUB LedOnOff
dira[3] := 1
dira[18] := 1
repeat
outa[3] := 1
outa[18] := 1
outa[3] := 0
outa[18] := 0
Jim
Riverpottery.com
Im upgrading the software so i can adjust it and display the setting on an LCD.Ill report later Jim
