Stamp tp control linear actuators
I have built a robot arm using re-purposed hospital bed linear actuators (115v, 2a) and am wanting to be able to control them with my BS2. I have heard that one way to do that is with DPDT Solid State Relays...will that work? If so, how can I protect the stamp from current spikes, and also how can I meet the coil activation requirements for the relay (it is a #275Radio Shack-217 125VAC/10A DPDT Plug-In Relay DPDT 10A at 125VAC 125VAC, 15mA, 4.5ohm). Or, is there a better way to go?
Thanks!
Thanks!
part# S202S02
Heres the link: http://www.parallax.com/Store/Components/Other/tabid/157/CategoryID/33/List/0/SortField/0/Level/a/ProductID/657/Default.aspx
This is just what you need. You also only need to switch the line side of your 125vAC circuit. the neutral is bonded to ground.
'I
It's good for 8 amps too
The I/O board will show you how to wire the SSR.
Good luck with your project and welcome to the forums.
