This is funny if you are at all interested in databases, plus ive got a question :-)
heck it out -> http://www.xtranormal.com/watch/6995033/mongo-db-is-web-scale
The question.
I have very limited idea on what a strain guage can do. Can I use it in conjustion with my car or bycicle along with a GPS ?
nother question
Are there any plans to have the prop IDE on the ipad ?
The question.
nother question
It's very unlikely.
Yes.
Please God no. Android would be better. Especially when I get hold of an ASUS Transformer Tablet.
A strain guage measures strain. Strain is to do with how much things are stretched. If you pull a wire tight and measure it's length L1 and then pull it tighter it stretches out to L2. The strain due to the extra pull is (L2 - L1) / L1
Now if you know something about the modulus of elasticity of the wire you can calculate the extra force that you applied to cause that much strain. And hence use this as a weighing scale.
The only strain gauges I have seen are thin resistive elements that you can glue to the side of metal bars and such. Bend the rod and the side under the strain gauge stretches. That changes it's resistance. Measure the change in resistance and you know the stain on that side of the bar under the gauge. Hence you can determine the load applied to the bar to bend it.
So, on a bicycle, say, stick a strain gauge to each peddle crank. Half way along. Measure the strain you apply in real time as you peddle. From that you have the amount of force applied to the peddles. From that and with the RPM you can work out how much power you are applying as you peddle. From that you can work out how many calories you have burned and how much less you are going to weigh:)
Combining with GPS is an exercise for the reader...
