NEW PIR Sensor
Hey everyone!
I just wanted let you know of the awesome updates we've made to the PIR Sensor - now for sale! We're really excited about the changes made to this sensor, and hope you enjoy them too.
Here's the rundown of latest and greatest improvements:
I've attached pictures to this post, and you can also check out the updated product page & documentation here.
Questions? Comments? Let us know!
Cheers,
Jessica
- Wider Supply Voltage Range: 3 to 6 V
- Output voltage is now within 10% of the supply voltage
- Higher output current: 12 mA @ 3V, 23 mA @ 5V (Yes, you can now directly drive an external load!)
- All parts SMD
- Jumper now controls distance: up to 15 ft on short setting, 30 ft on long setting
- Mounting holes for 2-56 sized screws
- Onboard LED under the lens for visual movement feedback
Cheers,
Jessica
Can you please check for us whether the new PIR sensor consumes more current than the old PIR sensor? (when idle and signal pin is not connected)
We are currently in the middle of a commercial product design that uses the PIR sensor but the product runs on batteries.
We are obviously very concerned about the current consumption figures.
Sorry it's taken me so long to get back to you. When idle, the new PIR consumes about the same amount of current as the previous version, ~130uA when no load is connected.
Hope this helps!
For how I am using the modules I like the addition of the LED for feedback. However there may be projects where you want to detect motion but not attract attention to the PIR sensor and having the LED may prevent it from being hidden. I think it would be good to have a jumper on the back to enable/disable the LED or even show in the docs if a trace can be cut to disable it.
So, to summarize I think all the changes are good with the exception of the jumper on the front (which I would move to the back). Also, find an easy way that the LED could be disabled (if someone wants too) and add that to the docs. Since the board is already done just a note pointing out what trace could be cut would be fine. I'll keep the LED active on mine (I'm a fan of LEDs) but I do think some projects may be better without them.
Robert
Thanks for your feedback. From this point forward, we will actually only be selling Rev B.
We've actually gotten a couple of requests for the jumper to be moved to the back, so I will see what I can do to change that moving forward. I'll also see what I can do about disabling the LED.
Thanks again,
Jessica
I'm fine with the LED and hope it stays but if you can find a mod to disable it for those that don't want it that will help.
Robert
I would also like to be able to disable the LED to save power.
We also were surprised to find the red LEDs (there are two of them flanking the sensing element) on the new revision of the 555-28027. It's critical for our application that the sensor remains dark, and it also hurts our energy budget. Another vote to put a jumper on for the LEDs.
As for fixing this, there is a small trace on the top of the board (lens side) that extends to one side of the Fresnel lens. It peeks out just beyond the lens and then goes to a via - if you cut that trace just before the via, the LEDs do not turn on but as far as I can tell the sensor still works. I called Parallax tech support and they verified that this solution should be sufficient and should not alter any other functionality.
Thanks!
Do you know what the shortest on time you can set it for? In other words, how long before you can rearm it again so that it can see a warm object?
Al
