Serial porting question
                    I have a serial device connected to P6 & P7. It uses the Full Duplex serial object to communicate. If I wanted to directly communicate with this device (for setup reasons I don't want to un-solder it) is is possible to utilize Full Duplex serial again with Parallax Serial Terminal on P30 & P31 in the same cog and just "pass through" the data back and forth between P6/P7 and P30/P31?
Could someone please pass on some example code how to "join" these different ports to one another? Or can it even be done? The serial device communicates with the prop at 115K baud so I'd want to communicate with PST at 115K. I would download this code just to program the device then reload the original spin program. I am just wanting to be able to setup the serial device without having to remove it. Something down and dirty simple.
Serial device <--P6/P7->Propeller<-P30/P31->PST via PC USB
Thanks.
Don
Thanks.
Don
repeat if (temp := port1.rxcheck) <> -1 port2.tx(temp) if (temp := port2.rxcheck) <> -1 port1.tx(temp)
