Need help dividing a variable... sytax question
So program specifics aside, i'm not actually using a stamp, i'm using a pic16f628a, running picbasic pro.
basically the exact same thing, just 40 bucks cheaper, and no built in regulator (like its good for anything anyway)
So in my program, i have a 4 digit variable, which is transferred to the chip through a series of pulses, via the COUNT command.
the Count result is stored as a 4 digit variable, which we will call X. Lets say that X has a value of 1234
i need to store each digit in a separate variable, and have it represented as a solitary digit.
so one variable is 1, one is 2, one is 3, and one is 4. The digit is needed for its binary value.
Now i know that i can select bits or bytes from a variable, but i dont know how to single out a numeric digit from a string, and store it
any ideas?
any ideas?
for anyone wondering:
an example;
for 38
38 in decimal, converted to binary is 0010 0110
naturally the first and second nybbles do not correspond to 3 and 8, since 3 is 0011 and 8 is 1000. i would need 00111000 in order to make the variable's bits useful
but 00111000 IS 38.
in hex.
so all i need to do is store my variable as a hex value instead of a decimal one, and the integers will be reflected as individual nybbles..
Here comes the last obstacle-
if i have a variable, 38. but i want to change it to $38. how would i add the $ prefix?
i thought about maybe something like "x=$(x) or the like, but i cannot seem to find the magic command
0011_1000 is 0x38 which is 56 decimal
What you want is called binary-coded decimal.
If you're writing the data to a screen you probably what ASCII encoding. Either way, binary-coded decimal or ASCII encoding are easy to find with an Internet search. You might even try picbasic pro support as this is a Parallax forum not a PIC or picbasic pro support forum.
I am also aware that 38 in decimal is 26 in hex- my point was that the end binary string i WANT, is the result of inputting the number i have available, but identified as a hex value instead of a decimal one. I'll avoid having it in decimal at all if i can.
All i need to know is this:
if i can say
A=10
B=A
how can i end up with
A=10
B=$A (in this case, $10)
how can i change the value of B, using a decimal number?
Picbasic is near identical to pbasic, but that's immaterial, since i'm using a bs2 to dry run the code since it has an easier debug function
The number can be represented by polynomial.
Your decimal example
1234
1*1000 + 2*100 + 3*10 + 4*1
Now you need to reverse the process by dividing the number (dividend) by divisor ( starting with the highest) getting the result ( quotient) and subtracting the polynomial member value.
In the attached example I used fixed length of four digits as you require, I'll leave it to your skills to apply this to any length / size of number and any numbering system.
Please - do not call the result / quotient BCD. The individual quotiens are still in binary, the entire representation of 1234 in your memory - four locations will be BCD.
' {$STAMP BS2e} ' {$PBASIC 2.5} DecimalDigit VAR Word ' dividend Index VAR Word Divisor VAR Word ' divisor Digit VAR Byte ' quotient Divisor = 1000 ' if a / b = c THEN a is the dividend, b the divisor, AND c the quotient. Main: DEBUG "Enter decimal " DEBUGIN DEC DecimalDigit DEBUG CR DEBUG ? DecimalDigit FOR Index = 0 TO 3 ' fixed / constant digits in number! Digit = DecimalDigit / Divisor DEBUG ? Digit ' wanted result DecimalDigit = decimalDigit - (digit * divisor) DEBUG ? DecimalDigit Divisor = Divisor/ 10 DEBUG ? divisor NEXT 'STOP ENDHere's lies the confusion because B is already equal to 10. Decimal 10 is 0x0Ah ($A). 0x10h ($10) is decimal 16. Logically, 10 does not equal 16 and therefore 0x0A does not equal 0x10.
The integer number ten can be represented as 10, 0x0A, $A, 100/10, 1 * 10 but it is always 10.
It sounds like you're trying to encode numbers. If you want 0x0A to take up two memory locations like | 1 | 0 | then you have to do what vaclav_sal suggested above. That's called BCD. If you added 0x30 to each of the memory locations, you would have the ASCII code for 1 (0x31) and 0 (0x30). Which if you sent to the DEBUG terminal would display 10.
