i would like to build a RS232 to TTL serial cable connector pinout
i would like to use the parallax basic stamp homework board ... the schematic can be found here ...http://pinouts.ru/Converters/rs232-TTL_cable_pinout.shtml to obtain the drive specific data (key/inquiry/identify/Serial) in my liteon which once extracted are used to create the dummy.bin .A popular variant can be bought for around 30 dollars . what im trying to do id all opensource and legit . was hopeing to get your thoughts and help thanks for your time
The Basic Stamp can use any pins for serial input and output. You don't have to use the programming interface (RS232) at all for your program. The Stamp's I/O pins should be able to connect directly to the Tx and Rx lines of the mobile phone as long as they're 5V TTL compatible. You'd use the SEROUT statement to transmit to the phone and the SERIN statement to receive from the phone. Remember that the Stamp can't receive and transmit simultaneously and reception isn't buffered.
None of this addresses the question of whether a Stamp can be used to do what you want. You've supplied very little information about anything other than what's suggested for a hardware interface. You're going to have to supply a lot more information to get any significant amount of help. Sorry.
or these http://www.team-xecuter.com/forums/showthread.php?t=48110
so i can do this http://www.youtube.com/watch?v=ZXoix6MIALM
in other words i have 6 kids 2 xbox 360's i pay 60 dollars for a disk it might last a month . well my other xbox has a hitachi dvd drive very simple process to modify so the xbox doesnt check for the "oem sticker" build into the disks . im not really sure of this site policy's i did some checking and didnt see any thing as far as rules and content of the forums . and i am sorry for the long period of time to get the piont .. as i was trying to fish for information with out saying to much because it is a controversial subject . but as i said before what i am trying to do is legal as i own both the game and the console and leagly can do what ever i want to them ... any who i hope i haven't stepped on anyones toes
If you want to use a Stamp for the interface, you'd need to provide at a minimum the description of the data that goes back and forth between the drive and the PC including the Baud used and any unusual formatting.
It's pretty simple really. For a cross spoof you need to replace 2 things apart from the key to make donor look like the recipient, the Inquiry and the Identify.
In most drives these are stored separately and can be simply over written.
They are also separate in the Lite-on BUT they have unique information in the them i.e. the drive barcode. The barcode is read from another area i.e. the 0x1FF00 serial area and superimposed on both the Inquiry and Identify as they are returned.......
This means that to spoof as a say hitachi you would need to write the part of the inquiry string used by the barcode to the barcode area in the lite-on firmware on hitachi this has readable information in it
0000: 05 80 00 32 5B 00 00 00 - 50 4C 44 53 20 20 20 20 ...2[...PLDS
0010: 44 47 2D 31 36 44 32 53 - 20 20 20 20 20 20 20 20 DG-16D2S
0020: 37 34 38 35 30 43 41 30 - 41 31 44 36 30 38 43 47 74850CA0A1D608CG
0030: 38 33 33 39 30 37 30 31 - 30 46 30 20 20 20 00 00 833907010F0 ..
0040: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0050: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0000: C0 85 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0010: 00 00 00 00 44 36 30 38 - 43 47 38 33 33 39 30 37 ....D608CG833907
0020: 30 31 30 46 30 20 20 20 - 00 00 00 00 00 00 34 37 010F0 ......47
0030: 35 38 43 30 20 20 4C 50 - 53 44 20 20 20 20 47 44 58C0 LPSD GD
0040: 31 2D 44 36 53 32 20 20 - 20 20 20 20 20 20 20 20 1-D6S2
0050: 20 20 20 20 20 20 20 20 - 20 20 20 20 20 20 00 00 ..
0060: 00 00 00 0B 00 00 00 04 - 00 02 06 00 00 00 00 00 ................
0070: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
0080: 03 00 78 00 78 00 E3 00 - 78 00 00 00 00 00 00 00 ..x.x...x.......
0090: 00 00 00 00 00 00 00 00 - 02 02 00 00 68 00 00 00 ............h...
00A0: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00B0: 20 20 00 00 ..
soooooooo
if you put Hitachi strings like these..
0000: 05 80 00 32 5B 00 00 00 - 48 4C 2D 44 54 2D 53 54 ...2[...HL-DT-ST
0010: 44 56 44 2D 52 4F 4D 20 - 47 44 52 33 31 32 30 4C DVD-ROM GDR3120L
0020: 30 30 37 39 30 42 4D 42 - 42 20 20 20 30 36 2F 30 00790BMBB 06/0
0030: 35 2F 32 35 20 20 20 00 - 01 00 00 00 00 00 00 00 5/25 .........
0010: 00 00 00 00 20 20 20 20 - 20 20 20 20 20 20 20 20 ....
0020: 20 20 20 20 20 20 20 20 - 00 00 00 00 00 00 30 30 ......00
0030: 39 37 20 20 20 20 4C 48 - 44 2D 2D 54 54 53 56 44 97 LHD--TTSVD
0040: 2D 44 4F 52 20 4D 44 47 - 33 52 32 31 4C 30 20 20 -DOR MDG3R21L0
0060: 00 00 00 0F 00 00 00 02 - 00 02 06 00 00 00 00 00 ................
0070: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 07 00 ................
0080: 03 00 78 00 78 00 78 00 - 78 00 00 00 00 00 00 00 ..x.x.x.x.......
0090: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00A0: 7C 00 19 00 18 42 00 40 - 00 40 18 42 00 00 00 40 |....B.@.@.B...@
00B0: 3F 00 00 00 ?...
now if you were to put the red area from the Hitachi inquiry into the into the serial are in the Liteon firmware... the identify would look like this
0010: 00 00 00 00 20 20 30 36 - 2F 30 35 2F 32 35 20 20 .... 06/05/25
0020: 20 00 01 00 00 00 00 00 - 00 00 00 00 00 00 30 30 ............00
Basically, the identify would be all wrong.
