Scribbler 2 Bluetooth programmer
Is there a simple way to use the Sparkfun Blue SMiRF (http://www.sparkfun.com/products/10269) to program the Scribbler 2? What I would like to do is to simply connect the TX/RX of the Blue SMiRF to the propeller pins 30/31. I believe that the logic levels are 3.3V for the propeller, so I would power the Blue SMiRF with the 3.3V regulator which automatically adjusts the logic levels to match the vcc.
I would prefer to leave the RS232 interface intact. I don't know if there is something special to do with the reset pin or if I would have to cycle the Scribbler after programming.
I would like to avoid converting the Blue SMiRF to RS232 and jacking into the DB9 external port.
Thanks in advance.
Thanks in advance.
