C3 Protoboard Engineering Drawings
I would like an Engineering drawing of the C3 Protoboard.
Key dimensions for header placement are apparently not available.
This is not an unreasonable request.
Any engineering support at all from Parallax or even from Andre' would be appreciated.
Would you prefer a PCB-exported DXF/DWG of both boards so that you can obtain every single dimension you may prefer, or a more fully-dimensioned graphic image showing the additional details about headers and connectivity between the two boards?
So that we can best help you please tell us what you expect. I think exported file could happen instantly, but I'll need to put the fully-dimensioned drawing approach into the queue to get done in the next couple of days.
Ken, Thanks for your quick response.
A standard engineering drawing in a .pdf file showing key dimensions for the C3 ProtoBoard is best.
I would like board outline, mounting holes, bottom side keep-out areas, any available board header inter-connections, and expected board to board clearance. It would be nice to have a perspective drawing of the stacking concept.
There are several boards that I want to design for C3 later and this information is key.
If the C3 ProtoBoard was available for sale individually, I would buy one for sanity check, but not for getting measurements.
When do you plan to release the C3 ProtoBoard as a stand-alone product?
--Steve
- Ken
So, here's what I did, I went into that original dimensioned drawing and added the locations of the headers. Each header cluster is on 0.1" spacing, so once you locate one, you have them all in any cluster. The coords of the top left cluster, right side, and bottom are all there. Took about 3 hours of photoshoping, since the image is already so busy. That said, I highly recommend that you use the gerber files for your reference, if you're going to make a PCB, then you should have a gerber viewer to open them up, then you can get any dim in seconds and double check. To that end, I have put the gerbers in standard format in a zip along with some photos, and the board itself dimensioned more thoroughly (which I will try to add to this reply). First, here's the zip:
ftp://ftp.propeller-chip.com/PropC3/Designs/Schematics/C3_Proto_Add_On_Dim_Gerbers.zip
And fingers crossed the BB let's me add a photo correctly, since I can't seem to add a file if I am not the originator. Nope, only allows links - that's lame
Let me know if this works out. Also, give ,me your address in a PM, and I will send you a blank C3 protoboard for referenece, I have 100 extra from a previous test run.
Andre'
Thanks.
Andre'
