Prop Proto Board Revisions - Consolidated Comments
Hey there,
I've taken another run through this thread http://forums.parallax.com/showthread.php?131077-Revision-Request-Propeller-protoboards-more-silkscreen-marking-on-bottom-of-board and consolidated the requests for revisions in the attached document.
We'll go over these suggestions internally for our next revision. The earliest we can get to it is June or so, which probably brings the new Prop Proto Board revision into inventory around September or October. We'll share the revisions with you before we go to production, too. I'm not sure who will be responsible inside Parallax but we'll be sure to ask that person to do a forum roundup to share our changes before we commit them to production.
Thanks to everybody who made contributions.
Parallax Inc.
Parallax Inc.
That way my SerPlug and 485Plug would work on the board...
2. 45305 (Blank 3x4 Proto Board): Prototyping grid.
3. 28150 & 28850 (BOE): AppMod connector.
4. New Prop BOE: 20-pin AppMod-style connector.
BTW, as a separate issue, the 20-pin AppMod-style connector on the Prop BOE should also line up with the AppMod connector on the Stamp BOE. This will permit the easy implementation of a solderless protoboard, like the one requested here:
Cross-product interoperability is the key. It makes the whole of the product line greater than the sum of its parts.
I'd also suggest adding one more row of pins between the power supply and the rest of the board so that it can be salvaged when nanoizing the protoboard and used for other purposes. That is possible now, but only if you unsolder the barrel jack before hacksawing down the third full row. After separation it's a nifty little power stick and I hate wasting the components when I just wanted the SMT prop and prototyping area.
For that matter I think there would also be a market for a lower cost version that is not stuffed with the power supply components for those wo are nanoizing and embedding in another device (*cough* photo frame *cough*)
I think typical users are much more likely to be interested in NTSC out than VGA. I have never installed the VGA connector on one but I've hotwired several for video. (Of course then I went and wrote some VGA drivers and found out my company doesn't mind spending $300 for a 7-inch monitor, but I don't use protoboards for that kind of project.) I see protoboard projects as being more likely to be embedded anyway and if you want video at all you want it for debugging, and NTSC monitors work fine for that, are cheaper, and the interface uses less pins.
What this shows: The vertical circuit board is an instrumentation amp cut (nanoized?) from a board I designed years ago. The orange WAGO connector by the servo holes is meant to receive a Wheatstone bridge. The instrumentation amp requires negative power so there is a 555-powered voltage inverter on the back of the protoboard. There is also a socket there that used to hold a uController.com SD card adapter. The WAGO connector on the right is meant to support off-board I2C, in this case a bunch of parallel I/O cards made by one of our manufacturers. (They have a couple of extra signals for reset and watchdogging.) Finally you can see that I hotwired video as I described earlier, and installed one jack for a PS/2 keypad. It was an experiment well worth doing even though it didn't work because of noise on the delta/sigma ADC (probably from the 555 oscillator) and the 32K program limit. I did use this to test some important code; the rest of the board I cut the instrumentation amp from implemented a fairly sharp 3-op-amp filter. With this board I proved I could emulate that filter in software, using one cog for two channels. That is a big win I have in my pocket for when I come up with a solution to the 32K problem and return to ADC land.
This is pretty much what I use on my TriBlade except the propplug and prop headers are not 0.1" apart so I use a cable and I use this to connect to each of my 3 props on the board. I only use a 3pin cable because grounds are connected. I am not sure if the grounds on the protoboard USB section should be isolated from the main pcb. Comments please??
Except for the sigma-delta ADC stuff I still don't see, from a signal-integrity standpoint, how an extra inch or two of trace length to the Prop could affect your app. You're already pretty spread out as it is. And if you were using a mezzanine board, you'd be adding much more trace length than that. Moreover, it kind of looks like we might get SMD pads for the sigma-delta stuff, which is really the only way to do it, due to through-hole component size and lead length. What am I missing?
I do agree with you, in most cases the extra lead length does not make a difference. I ask though what happens when you have 8 Sigma Delta ADCs on a single prop? Are you suggesting that parallax provide surface mount pads for all 32 IOs? of course it is possible to overcome this also by making sure that line lengths match perfectly and the capacitance of the lines is minimal and exactly known.
My point is that I crammed an awful lot of stuff on that board. Having the prop in the center was not a problem. And if I needed more, I'd throw your point right back at you; you could use a shield-like second storey and have all the real estate you want for prototyping. For the "a few resistors" thing the center arrangement works better and is more versatile. If you really need prototyping real estate it should be on a shield.
Perhaps leave out the PS/2 and VGA space and use the VGA-PS/2 Adapter Board Kit ( http://www.parallax.com/Store/Accessories/CablesConverters/tabid/166/CategoryID/40/List/0/SortField/0/catpageindex/2/Level/a/ProductID/583/Default.aspx ) in the Proto Board Accessory kit (still making available the older version of the accessory kit).
So, if I were to only make one change, I'd add one or two (or maybe 3) RCA jacks.
I do know that many use VGA, and some do not have NTSC or PAL monitors. Perhaps use some of the unused VGA pins to accomplish a couple RCA connectors for NTSC/PAL and audio, via a short cable, so as not to take any board space (this would mean having a couple of diodes on the VGA so we do not send it the NTSC/PAL or audio).
However, I suggest rotating the prop section by 90 degrees clockwise so that P0-7 and P8-15 are closer to the larger prototyping areas.
