3.3v Regulator Problem
I bought a couple 3.3v regs from parallax but am having trouble with both of them. I have them hooked up according to the datasheet, feeding them with an 8.5v 250mA power supply but instead of outputing 3.3v they are outputing 7.5v. Is it possible that they are defective? I really don't see how I could be using them wrong. Any suggestions?
wiring is incorrect. Do a google image search on the regulator
and you should turn up some pictures of the regulator wired
correctly.
the datasheet ,same pins assignment as the common 7805 or 7812
never could get it to function,always put out about 0.5 volts less than input.
Just assumed I got a bad one. or I zapped it when I touched it.
mine was labeled LM2937ET -3.3
no big deal, just used a LM317 adj one I had
7805 or 7812, according to the datasheet, I would assume the datasheet is correct
Datasheet is from Parallax and is the correct data sheet for the number on the part itself
I would not connect it without verifing that.
Anyway it is only a $1.25 part. just info for others if they have a problem
UPDATE: MY APPOLOGIES, I just tested again and apparently, just like datasheet
says, a 10uF cap on at least the output is NECESSARY for this regulator to even function.
Apparently even when immediatedy following another clean stable regulator, and no matter the output load.
Now with the cap it jumps to 3.3v and is steady under different loads.
I had never experienced this behavior before with 3 legged regulator, mostly
the 78xx series. Of course this is NOT a 78xx series.
Thanks Phil and Leon for the hints!
finicky....this is good to know! :-)
In other words, you cannot merely swap an LDO for a 7805 in a circuit and expect it to behave. These are NOT generic replacements.
