PLEASE HELP! Viewport Issues — Parallax Forums
albertalbert Posts: 10
edited 2011-04-21 13:00 in General Discussion
even though we have all the "right" equipment, downloaded FTDI from parallax.com etc. STILL does Viewport give us the same error "Failed to configure on COM13".
Can somebody just give me one simple explanation.
Sincerely Albert.
  • vaclav_salvaclav_sal Posts: 451
    edited 2011-04-20 12:19
    What Ports do you see in Device Manager?
    You probably have wrong COM port number configured.
  • albertalbert Posts: 10
    edited 2011-04-20 12:32
    Hello, yes I'm using the right COM port. In device manager i can see 7, 8 and 13. But using the wrong COM port gives a totally different error message saying propeller not found (I just tried), which means that this is not the problem. It recognizes that there is a propeller connected to this port, but it can't configure it for some reason.
    edited 2011-04-20 15:39
    Do you already have a program on your Propeller?
    If you have a serial port program running than it is probably blocking ViewPort. To make sure a program on the Propeller isn't causing this, open up Propeller Tool and type "PUB Start" into the blank editor. Click F11 (Load EEPROM) and then try Viewport. If the now-clear Propeller still doesn't work, you may try changing USB cables. I don't know how but when I had this problem that is what worked.
  • HannoHanno Posts: 1,130
    Hi Albert,
    Here's another thread with several things to try:
    http://forums.parallax.com/showthread.php?130129-Viewport-unable-to-connect-to-my-boards&highlight=viewport
    Main issues:
    - make sure you're using a good USB cable- not the retractable one that Parallax supplies
    - start by using known good "Tutorial" programs
    It doesn't matter what is in the Propeller's EEPROM, ViewPort will reset, load, run, and then establish communication with the program.
    Hanno
