Max4411 headphone amp breakout board
I was wondering if anybody sells a Max4411 headphone amp breakout board? I would like to use the wav player object with a non-demo board propeller set-up.
Or is there a thru-hole version of this IC?
But the other features would broaden the demand for it.
Just tried to help out.
Personally, having the Propeller able to mix sound with other sources is appealing to me.
I have a project built on a ppdb that really needs to find a new (permanent) home...
The schematic for the ppdb circuit doesn't seem to be too intimidating. I suppose i could just build it. Weird that i cant find something comparable to this in a breadboard friendly fashion... other than the $60 eval board, which is um, just a bit overboard.
found two boards that might work for those looking for a similar solution:
Teensy Audio board: https://www.sparkfun.com/products/12767
PAM8403 breakout board http://www.ebay.com/itm/161116580464
What input connector would you like?
Some background on the project...
I'm building this Sid Dump player for my brothers bday. Inspired by the SidStick that used to be for sale over on gadget gangster. My implementation will include a few input buttons for mode selection, and a small display for file navigation. I've settled on the project board as basis for the unit. I'm toying with two different display options right now, not sure I want to give up my uOLED128 or instead just use a monochrome 128x32 OLEDs from adafruit. The original version i cooked up (on the ppdb now) uses rca video out, but the more i think about it, the device will be more practical with a built in display.
I'm looking for a suitable stereo socket. I have some expensive professional ones but they seem to require a slightly bigger plug than the standard ones, which don't make proper contact.
