WAITCNT causing REPEAT block to only cycle twice. -also: budgeting clock cycles
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ Debug: "FullDuplexSerial" PUB TestMessages ''Send test messages to Parallax Serial Terminal. Debug.start(31, 30, 0, 57600) repeat waitcnt (1000) waitpeq (%00000000000000000000000000000000,%00000000100000000000000000000000,0) waitpeq (%00000000100000000000000000000000,%00000000100000000000000000000000,0) Debug.str(string("1", 13))
I have an infrared LED and infrared phototransistor from the PE propstick usb Kit on the proto board. When I point the LED at the phototransistor and then away, I get multiple "1"s on the terminal if i do not have the waitcnt. When I add the waitcnt to help filter some of the multiple hits, i will get two 1s at most and then no more responses. Am I missing something simple?
The value you pass to waitcnt is an absolute value that the propeller internal counter named CNT has to reach until waitcnt continues. CNT is increased with each clock cycle. Depending on what the current value of CNT is when you call waitcnt 1000 you will have very different wait-times. Say CNT is 900 when calling waitcnt 1000 this waitcnt will only wait 100 clock cycles. If CNT is 1001 when calling the wait passed the exact match and will wait until CNT is back at 1000 again. This takes roundabout 50seconds.
So, if you want to wait for a fixed time, you have to do
waitcnt CNT + 1000
If you want fixed periodes you need a helper variable
timeToWaitFor = CNT
repeat
waitcnt timeToWaitFor+=1000
waitcnt( 1000 + cnt ) 'right way
vs
waitcnt( cnt + 1000 ) 'not wrong, but less safe - cnt is read first, then the 1000 is added, meaning more time will elapse before it actually starts to wait
Welcome to the forums!
So now you know how many cycles it takes for those instructions to execute. Whatever is left over is how long you actually spent waiting. So then, if you're waiting for a real event, like an optical trigger on an optical sensor, you can subtract the TimeTaken value from the answer you get and it'll be more accurate.
You might also want to look at the FRQA & CNTA registers. It's possible to configure them to count pulses (rising or falling edge) from an external source (input pin). You can keep track of how much time elapsed since you last checked the counter, and how many pulses it got since then, and calculate your RPM value from that. And you won't need to dedicate a cog to it.
For something that's rotating very slowly, counting how many cycles elapsed between pulses is going to give you a more accurate answer, so it depends on your needs. With a dedicated cog, 3000 samples per second isn't a challenge in spin. I would guess you could do 20KHz or better with no problem.
