Compile the code into the Propeller Demo Board by wireless??
Hello everybody ~
I tried to compile my program into the Propeller Demo Board by wireless.
Can I connect the XBee modules's Rx pin and Tx pin with Propeller's other pin instead of pin30 and pin31?
Are there any suggestion or any demo code?
Thanks a lot !!
Thanks a lot !!
http://forums.parallax.com/showthread.php?127780-Upload-Prop-programs-via-XBee&p=989026#post989026
http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/741/Default.aspx?txtSearch=wireless+usb
Yes, that was my first thought but called Parallax and they said it will not work on my computer because of the Windows 7 64 bit.
I still think that's strange because it works on Windows Vista 64 bit?
So, if anyone out there has the USB Hub working on Windows 7 64 bit I would like to know.
The Xbee works good but it's a little bit of a hassle when using the same XBee to send data from Bot to PC and the use of a COG.
