Switching AC loads with a Bridge Rectifier?
I read in a few places that AC loads could be effectively switched with a Bridge Rectifier, as in:
"Another possibility for switching an AC load is to put it in series with the input (AC) terminals of an appropriately rated full-wave bridge." ( http://forums.parallax.com/showthread.php?67538-Switching-AC-DC-Relays-and )
While this may be an outdated method, I am very interested in this configuration and I am wondering if any of the resident gurus here might be able to point me toward a schematic that would illustrate this configuration and how it works... so far, it isn't seeming obvious to me, and I'm finding nothing of use online except vague references in passing to this.
Thanks for the info,
Dave
Dave
Dave
The device across the +- contacts of the bridge rectifier could be a fet, bipolar transistor, SCR, or TRIAC. Of course the bridge rectifier is not needed with a TRIAC.Attachment not found.
Dave
Do be careful when playing with this, especially if you hook it up to 120VAC. The drive for the fet/bjt/scr needs to be isolated unless you are using an isolation transformer secondary as the AC source.
Dave
