ULN2803 as a relay driver - LED/Spike diode question
Hi all, I'm driving relays from a BS2SX via some 74HC595s and ULN2803s. My question is - I need to add status LEDs AFTER the ULNs- but that also effectively puts them out of the built-in spike protection fo the ULNs, I am thinking. Would the reverse voltage rating of the average LED handle the spike of the relays, or do I need to add another diode (like a 1N914) to protect said LED... The relays coils operate on 5vdc and I'll be using a 1K current limiting resistor with the LED (dark environment, they don't need to be very bright...) Thoughts?
Thanks!
Dave
Of course, looking at the schematic of the ULNs... maybe that diode WILL still provide the protection... still - rather check with those potentially wiser than I in this issue... :-)
Thanks!
Dave
The Parallax relay board uses a similar method of adding a status LED as shown in the schematic here:
http://www.parallax.com/Portals/0/Downloads/docs/prod/boards/DigIOBrdSchem.pdf
Robert
Confirmation AND reassurance in one response, thanks very much!!!
Dave
