retriving code from BS2
Embarassing to admit, but I made a change to some BS2 code that made my project do just what I wanted it to do. Too bad I didn't save the change to my PC :-(
How can I download the code from the stamp?
John
John
Dumping the contents of the EEPROM yields only "tokens", and being the result of a compile and download are not readable.
DJ
John
http://forums.parallax.com/showthread.php?131299-Tutorial-Retrieving-EEPROM-Data-From-BASIC-Stamp-Modules
Yea/Nea?
Update...I just explored the Stamp editor and could find no feature for saving a tokenized version of code. There is the "Generate Object Code" function, but it appears to just download to the Stamp.
There is a Memory Map utility in the run drop down.
@Mr. Green - ouch! This could be a candidate for the "you're an old geek if..." thread started by Bean. Just a couple weeks back I pointed another Forum member to this exact place in the manual...and completely forgot about it!
http://forums.parallax.com/showthread.php?120257-EEPROM-Dump-Utility&highlight=code+eeprom
http://forums.parallax.com/showthread.php?120913-Can-the-stamp-code-be-copied&highlight=code+eeprom
http://forums.parallax.com/showthread.php?120113-Retrieve-code-from-old-BS2-Chip&highlight=code+eeprom
http://forums.parallax.com/showthread.php?118536-how-to-retrieve-bse-code&highlight=code+eeprom
http://forums.parallax.com/showthread.php?107755-Pulling-code-off-a-BS2&highlight=lost+program
