DS1620 Question/Problem
Has anyone experienced any problems with the DS1620 giving the correct temperature with the Propeller? I am using the code downloaded from the OBEX site and have everything connected properly. The problem I am having is that the temperature is reading about 30 degrees F more than it should. If I put my finger on the chip, the temperature rises (as it should). It could simply be a bad chip, but I was curious if anyone has had similar problems.
Thanks for any help.
I'm assuming you had the same/similar problem? I just got a new one, and it works perfectly.
