DC1302 Time Chip Coding Problem
I have a simple code that sets the time and then records the time every 30 seconds or so using a data logger but for some reason the timing is not working. I put together the code using the demo code that the parallax site has and I've hit quite a road bump. I can't figure out what part of the demo code actually makes the timing chip keep time. When I run the demo its fine so its connected properly but when I run my code it logs the same time that I set over and over again. I have put the code here too but if anyone can explain what is wrong with it that keeps it from actually keeping the time. Any help is appreciated.
' {$STAMP BS2e}
' {$PBASIC 2.5}
' -----[ I/O Definitions ]-------------------------------------------------
OUTPUT 4
OUTPUT 3
DataIO PIN 0 ' DS1302.6
Clock PIN 1 ' DS1302.7
CS1302 PIN 2 ' DS1302.5
LED PIN 3
LED1 PIN 4
TX PIN 8 ' Transmit Data --> 27937.4 (RXD)
RTS PIN 9 ' Request To Send --> 27937.6 (CTS)
RX PIN 10 ' Receive Data <-- 27937.5 (TXD)
CTS PIN 11 ' Clear To Send <-- 27937.2 (RTS)
' -----[ Constants ]-------------------------------------------------------
Baud CON 84 ' Serial Baud Rate 9600 bps (BS2)
NumSamples CON 1 ' Number Of Samples To Log
WrSecs CON $80 ' Write Seconds
RdSecs CON $81 ' Read Seconds
WrMins CON $82 ' Write Minutes
RdMins CON $83 ' Read Minutes
WrHrs CON $84 ' Write Hours
RdHrs CON $85 ' Read Hours
CWPr CON $8E ' Write Protect Register
WPr1 CON $80 ' Set Write Protect
WPr0 CON $00 ' Clear Write Protect
WrBurst CON $BE ' Write Burst Of Data
RdBurst CON $BF ' Read Burst Of Data
WrRam CON $C0 ' Write RAM Data
RdRam CON $C1 ' Read RAM Data
Hr24 CON 0 ' 24 Hour Mode
Hr12 CON 1 ' 12 Hour Mode
' -----[ Variables ]-------------------------------------------------------
buffer VAR Byte(15) ' Input Buffer
index VAR Byte
ioByte VAR Byte ' Input/Output Storage
reps VAR Byte
reg VAR Byte ' Read/Write Address
secs VAR Byte
secs01 VAR secs.LOWNIB
secs10 VAR secs.HIGHNIB
mins VAR Byte ' Minutes
mins01 VAR mins.LOWNIB
mins10 VAR mins.HIGHNIB
hrs VAR Byte ' Hours
hrs01 VAR hrs.LOWNIB
hrs10 VAR hrs.HIGHNIB
date VAR Byte
month VAR Byte
day VAR Byte ' Day
year VAR Byte ' Year
' -----[ EEPROM Data ]-----------------------------------------------------
Sun DATA "SUN", 0 ' Day Abbreviations
Mon DATA "MON", 0
Tue DATA "TUE", 0 ' These data statements could
Wed DATA "WED", 0 ' contain the full day name and
Thu DATA "THU", 0 ' the code would still work
Fri DATA "FRI", 0 ' without change.
Sat DATA "SAT", 0
' -----[ Initialization for Disk Drive]--------------------------------------------------
DEBUG CLS, "Memory Stick Datalogger Demo V1.0", CR, CR, "Initializing..."
PAUSE 200 ' Allow Time To Settle
HIGH TX ' Initialize Transmit Line
LOW RTS ' Take Vinculum Out Of Reset
PAUSE 600 ' Allow Time To Settle
DEBUG "Done!", CR, "Synchronizing..."
DO
SEROUT TX\CTS, Baud, ["E", CR] ' Sync Command Character
GOSUB Get_Data ' Get Response
PAUSE 250
LOOP UNTIL ioByte = $0D ' Wait For Carriage Return
DO
SEROUT TX\CTS, Baud, ["e", CR] ' Sync Command Character
PAUSE 250
DO
PAUSE 250
DO
PAUSE 250
' -----[ Program Code ]----------------------------------------------------
Main:
DEBUG "Done", CR, "Switching to Short Command Mode..."
SEROUT TX\CTS, Baud, ["SCS", CR] ' Switch To Short Command Mode
GOSUB Get_Data ' Purge Receive Buffer
DEBUG "Done!", CR, "Waiting for Memory Stick..."
Check_Drive:
DO
SEROUT TX\CTS, Baud, [CR] ' Prompt Device For Status
IF buffer(0) = ">" THEN ' Check For Ready Prompt
EXIT ' If Ready Then Exit Loop
ELSEIF buffer(0) = "N" AND buffer(1) = "D" THEN
DEBUG "." ' Device Ready But No Memory Stick
ELSEIF buffer(0) = "D" AND buffer(1) = "D" AND reps = 0 THEN
DEBUG "Connected!", CR, "Accessing..."
reps = 1 ' Memory Stick Ready
ELSE
DEBUG "."
ENDIF
PAUSE 250 ' Command Retry Delay
LOOP
DEBUG "Ready!", CR
' -----[ Initialization for Time Chip]--------------------------------------------------
Init:
reg = CWPr ' Initialize DS1302
ioByte = WPr0 ' Clear Write Protect
GOSUB RTC_Out ' Send Command
'------------------[Setting Time]-------------------------------------------------------
Start:
DO ' DEBUG Menu
DEBUG CLS ' Clear The DEBUG Screen
DEBUG CRSRXY, 0, 0, "Press 1 to Set Date/Time.", CR
DEBUGIN DEC1 reps ' Get 1 Number
IF reps = 1 THEN
GOSUB Set_Mode
GOSUB Set_Time
GOTO Record_Data
ENDIF
LOOP
Record_Data:
FOR reps = 0 TO 10
SEROUT TX, Baud, [$09, $20, "datafile.txt", CR]
SEROUT TX, Baud, [$08, $20, $00, $00, $00, $10, $0D, CR,
HEX2 month, "/", HEX2 day, "/", HEX2 year, "_", HEX2 hrs, ":", HEX2 mins, ",", CR, LF, CR]
PAUSE 500 ' Write walked through door after handwash used = 1
' Close File (MUST CLOSE!)
SEROUT TX, Baud, [$0A, $20, "datafile.txt", CR]
DEBUG DEC reps
PAUSE 30000
NEXT
DEBUG CLS
DO
DEBUG CRSRXY, 0, 0, "Done", CR
LOOP
' -----[ Subroutines ]-----------------------------------------------------
Get_Data:
index = 0 ' Reset Index Pointer
DO ' Receive Data
SERIN RX\RTS, Baud, 100, Timeout, [ioByte]
buffer(index) = ioByte ' Add Received Byte To Buffer
index = index + 1 ' Increment Index Pointer
IF index > 14 THEN Timeout ' Check For Overflow
LOOP
Timeout:
RETURN
Set_Mode:
DEBUG CRSRXY, 0, 0, "Enter 2 digit year, i.e. 05 = 2005:", CR
DEBUGIN HEX2 year ' Set Year
DEBUG CRSRXY, 0, 1, "Enter 2 digit month, i.e. 03 = March:", CR
DEBUGIN HEX2 month ' Set Month
DEBUG CRSRXY, 0, 2, "Enter 2 digit date, i.e. 02 = 2nd:", CR
DEBUGIN HEX2 date ' Set Date
DEBUG CRSRXY, 0, 3, "Enter day of the week as a number 1-7", CR
DEBUG CRSRXY, 0, 4, "1=SUN, 2=MON, 3=TUE, 4=WED, 5=THU, 6=FRI, 7=SAT", CR
DEBUGIN HEX1 day
DEBUG CRSRXY, 0, 6, "Enter 2 digit hour, 00-23:", CR
DEBUGIN HEX2 hrs ' Set Hours (24 Hour Mode)
DEBUG CRSRXY, 0, 8, "Enter 2 digit minutes, 00-59:", CR
DEBUGIN HEX2 mins ' Set Minutes
' Setting clockMode to modeFlag will effectively
' set or clear BIT7 in the hrs variable.
' Setting ampm to ampmFlag will effectively set BIT5 in the
' hrs variable to the proper value.
' This must only be done when modeFlag is set (12 Hour Mode),
' otherwise you can destroy hours above 19 in 24 Hour Mode.
DEBUG CRSRXY, 0, 9, "Press ENTER to set time.", CR
DEBUGIN reps
RETURN ' Send Time/Date To DS1302
Set_Time: ' DS1302 Burst Write
HIGH CS1302 ' Select DS1302
SHIFTOUT DataIO, Clock, LSBFIRST, [WrBurst]
SHIFTOUT DataIO, Clock, LSBFIRST, [secs, mins, hrs,
date, month, day, year, 0]
LOW CS1302 ' Deselect DS1302
RETURN
Get_Time: ' DS1302 Burst Read
SHIFTOUT DataIO, Clock, LSBFIRST, [RdBurst]
SHIFTIN DataIO, Clock, LSBPRE, [secs, mins, hrs, date, month, day, year]
RETURN
RTC_Out:
SHIFTOUT DataIO, Clock, LSBFIRST, [reg, ioByte]
RETURN
As long as you don't overwrite those registers, the unit will keep time.
I used the same demo code and the system has been running over a year.
You'll have to check your code to make sure you aren't mistakenly changing the registers due to running out of variable space or when you come back from running another program slot.
