WiFi antenna
Have any of you guys had any experience with small stick on WiFi antennas.
We are working on an Ip Pad and don't want to mount an external antenna.
Whatever it is, don't forget your primary job here on the forum: politely and patiently but persistently prodding Parallax (the 5 P's) for their next chip, as you have convincing clout from not only a significant number of shipped PoS products using the current chip but a clear need for the next generation chip in a follow-on design.
Anyway, apologies for my non-informative reply (though the clarification request and/or bump might help), but good luck incorporating that WiFi antenna. By the way, what is the shape of those stick-on antennas?
reader and a biometric finger scanner as well as a LCD display. All of our products are Propeller powered and we want to
build a battery powered PAD device that uses WiFi or Ethernet (Ip) with PoE for communication.
Most schools have Ethernet or WiFi but we don't want to have an external antenna, kids are pretty tough on our products
and it would be to easy for the antenna to get broken.
Sooo, do you know anything about stick on patch antennas ? They are usually rectangular in size and have a shot cable
with a miniature connector.
1. http://www.wifi-toys.com/mo-wifitoys-chapter01.pdf
2. http://wn.com/patch_antenna
We are using the Lantronix Match Port B/G in all of our Ip designs. It is in expensive ($50)
does both Ethernet and WiFi and will bridge between the two.
