FM as non contact switch device ... possible?
vixtr
Can an FM radio transmitter / receiver combination be configured to detect the presence of the radio signal as it passes along a path perpendicular to an isolated receiver?
1) A 200 foot FM broadcast range radio will pass within 10 feet of the receiver at a rate of not more than 10 meters / second
2) Can an FM receiver can be isolated in such a way that it can act as a laser in order to start a timing devise when the FM signal crosses a boundary i.e. can the receiver be shielded in a way that it could detect the transmission when the radio passes a certain point in relation to the receiver?
3) Multiple persons may pass in front of the system, We want to detect an individual outfitted with a FM broadcaster set to a particular (unused locally) frequency.
You might have better luck using an IR emitter and a simple IR sensor. Must it be radio?
Otherwise, while I think you're using a few words wrong what you're probably trying to do is possible in a general sense. A simple way to do this would be to have the FM transmitter send an audio modulated signal (FM modulated tone). The receiver audio output could then be fed through an active filter or even just rectified and straight (through a current limiting resistor LOL) into a digital input of a microprocessor to provide detection.
We're timing runners, cyclists Etc on a closed track and want to get start/stop times over various distances depending on where we set the "units". We have non participants in the loop so our individuals need to carry identifiers. Can IR be configured to detect a moving target as it passes a predetermined point?
One quick question: are your participants able to pass by something to identify themselves? Your scenario sounds almost like a marathon in which some runners are getting timed. If the runners want to be timed, can they pass within a foot or so of a detector? I was thinking perhaps a RFID system might be of some help. If you've got a bunch of random people wandering around, your IR detection systems might have some troubles. A RFID could possibly identify each participant individually, but I'm not sure what the range is on something like that.
