xbox360 joystick button modification with a basic stamp
I would like to use a basic stamp to automatically truncate (cut off) the signal from a pushbutton micro switch as quickly as possible. Maybe as quickly as 1ms or if not, how fast thcould this be done? I was wondering if this could be done with some sort of cheap relay. If so, is there something that would respond in 1/60 second?
You may ask, why would I want to do this? I want to be able to press the same button again as quickly as possible without actually releasing the button. If the signal is cut off automatically for me, I can register the same move again with another switch. Hopefully you can see where I'm going with this, it is a sort of modified legal turbo that could be used for tournament play.
Please let me know if you have any ideas, any input is very much appreciated.
-wes
-wes
The BS2 should be able to do what you want. But I won't give you ideas for this one...Haha!
