Please add "pin to hole" measurements to the micro-SD Card Adapter #32312, PDF
Capt. Quirk
micro-SD Card Adapter (#32312) v1.0 9/11/2009 Page 2 of 3
Needs additional width measurement from center of pins to the center of the mounting holes. Additional mounting hole information would be helpful for pcb design.
Thank you.
Thank you.
The measurement from center of pins to the center of the mounting holes is .6" or 15.25mm. The center of the mounting hole to the opposite side of the board regarding the pins is .275" or 7mm. I hope this helps and the document will be updated.
regards,
Dave
