Mac OS Classic Compiler.
I am in one heck of a predicament, my surge protectors are going off way to often even when I lighten the power load as much as I can with a PC. The only systems I have that could get rid of this issue (by taking very little power), are an Amiga, a Macintosh G3 (to slow for OS X), and an Apple IIGS. Out of the systems mentioned the only one that is popular enough to make the needed request for is Mac OS Classic, as such I ask:
Will someone PLEASE, port a SPIN/Propeller assembly compiler, and loader (using the FTDI for the Prop Plug) to Mac OS Classic (it can be carbonized, I run OS 9.2.2). In advance I thank whoever does so. Also I know a few people who do not yet use the Prop because of the lack of any tools for there platforms, including Mac OS Classic, AROS, Amiga OS 4.x, Haiku OS, etc.
If you can't get your current Mac running OSX, then my next suggestion would be to invest in a netbook or laptop. Netbooks typically require about 40 Watts while charging, and cost about $200 on sale (new).
David, I'm a little puzzled by your post. Surge protectors are generally used to protect equipment from high voltage spikes and other brief increases in line voltage. Equipment that draws large currents tends to decrease the line voltage. How does switching to a computer that draws less current thus resulting in a higher line voltage help?
I do not know. I do know that the less current on the circuit the less often it cuts off at the surge protector (the device must also switch on high current conditions [probably to protect against a short]).
Are you living off-grid by any chance? It's hard to imagine issues such as those you report if a solid utility is providing power.
and are some what "modern" . a G4 is like 300 with ship on ebay and a Core solo is 300 or so too..
Peter
The first one I lived in really didn't account for voltage drops well. 14 ga wire was common! I re-did it with 10 from the mains to room junctions, then 12 to outlets, with a dedicated circuit for some higher draw things. Before that, brown-outting was common, depending on a lot of things.
