How do you save data in more than one slot in the DS1302 time chip Example given ..>
How would put the next event in the next memery slot and know when the memery slots were full ?
I know how to put Data each memery slot with the VAR WORD
I want to put more than one Event_seconds in memery
Is there a way to this with out doing that way
I can get this to work how ever I do not want to use a computer to use this I want the Basic Stamp to save the even which i can not get this to work
WriteRam: ' Routine to Save Data to a DS1302 Time Chip reg = $FE ' Send Command HIGH Timer SHIFTOUT DataIO, Clock,LSBFIRST, [reg] SHIFTOUT DataIO, Clock, LSBFIRST, [Total_Secs.HIGHBYTE,Total_Secs.LOWBYTE,Event_Secs.HIGHBYTE,Event_Secs.LOWBYTE] LOW Timer RETURN ReadRam : 'Routine to Read Data from DS1302 Time Chip reg = $FF HIGH Timer SHIFTOUT DataIO, Clock, LSBFIRST, [reg] SHIFTIN DataIO, Clock, LSBPRE, [ Total_Secs.HIGHBYTE,Total_Secs.LOWBYTE,Event_Secs.HIGHBYTE,Event_Secs.LOWBYTE] LOW Timer DEBUG HOME, "TotalSecs = ",DEC5 Total_Secs," Event_Secs = ",DEC5 Event_Secs , CR, RETURN
RAM_Mode:
DO
DEBUG CLS, "Enter an address from 0-30 (>31 Exits):", CR
DEBUGIN DEC2 index ' Address in DS1302 RAM
IF index > 30 THEN EXIT ' Exit if out of range
DEBUG CRSRXY, 0, 1, "Enter # from 0-255 to store at ", DEC index, CR
DEBUGIN DEC3 ioByte ' Value to store in DS1302 RAM
DEBUG CRSRXY, 0, 2, "Storing ", DEC ioByte, " at ", DEC index, CR
' The address to store data in the DS1302 RAM is obtained by OR-ing
' the command byte with the address shifted left one bit. This is
' because the command byte uses BIT0, BIT6 and BIT7. The address
' occupies BIT1 through BIT5. You are effectively putting the address
' in BIT1-BIT5 of reg.
' Write RAM command = 11xxxxx0 (Uses 3 bits)
' Read RAM command = 11xxxxx1 (Uses 3 bits)
' xxxxx = address (Uses 5 bits)
reg = WrRam | (index << 1) ' RAM Write Mode + Address
GOSUB RTC_Out ' Send reg + ioByte
ioByte = 0 ' Clear Data Variable
reg = RdRam | (index << 1) ' RAM Read Mode + Address
GOSUB RTC_In ' Get Data From Address
DEBUG CRSRXY, 0, 3, "Address ", DEC index, " contains ", DEC ioByte, CR
DEBUG CRSRXY, 0, 4, "Press ENTER.", CR
DEBUGIN work
LOOP
RETURN
