FYI: Potential Gotcha with multi-core processing — Parallax Forums
Beau SchwabeBeau Schwabe Posts: 6,576
edited 2011-04-07 21:00 in Propeller 1
The original code was from a friend of mine asking for programming help.
The idea of the code operation is to sync two or more Propellers to an event initiated by a master Propeller. As it is the Propellers should be able to communicate asynchronous serial between one another.
So, the flow should go something like this ...
1) Master sends a broadcast command via asynchronous serial to all other Propellers that a synchronized event is about to happen.
2) This cues the Clients to 'look' for the sync pulse, initiating the event.
3) Over the same transmission line, the master Propeller sends out a 'sync pulse' which is NOT asynchronous serial.
4) The Clients see the pulse and execute code accordingly.
This seems pretty straight forward in the approach, but it won't work as described. Why?
Answer)
Since the FullDuplexSerial object as well as other serial objects operate out of their own cog, It's possible to send serial commands to the FullDuplexSerial object and return to the calling cog BEFORE all of the serial data has been sent. This is especially true if your baud rate is slow. In this scenario the Master could send the request, and the sync before the serial data had completed from the FullDuplexSerial object, thus corrupting the serial data. As a result of the corrupted data, the Client's would never be able to determine that there was an upcoming sync event at all.
To visually see this, look at the attached image with reference to the commented corrected code.
Below is the original code sent to me trying to accomplish this task.
CON
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000
OBJ
Ser     :       "FullDuplexSerial"     'Used for Debug output
CON
RX = 31
TX = 30
SyncBit = 37
Pub Start
Ser.start(RX,TX, 0, 9600)
repeat
  Ser.str(string("Serial Enabled"))
  Ser.tx(13)
  Ser.tx(SyncBit)
  Ser.stop
 ' waitcnt(cnt+clkfreq/5000)
  'DirA[TX]~~                                          'Set the direction bit to write out
  'OutA[TX]~~                                          'Set the pin to High to signal all other devices that sync has occured
  'DirA[TX]~                                           'give up control of the pin
  Ser.Start(RX,TX,0,9600)                              'restart serial
Below is virtually the same code with comments and corrections.
CON
OBJ
CON
RX = 31
'TX = 30
TX = 7          '<- for scope debugging only
SyncBit = 37
Pub Start
'Ser.start(RX,TX, 0, 9600)      '<- can't just run inverted mode, need to run open-drain
Ser.start(RX,TX, %0100 {<-mode open drain}, 9600)
'' mode bit 0 = invert rx
'' mode bit 1 = invert tx
'' mode bit 2 = open-drain/source tx
'' mode bit 3 = ignore tx echo on rx
OutA[TX]~                       'preset TX Low ; this way all we need to do is control direction
                                '                and it allows for open drain style control
repeat
  Ser.tx(13)
  Ser.tx(SyncBit)
' Ser.stop                      '<- don't do this! too much overhead in stopping/starting a new serial driver
' waitcnt(clkfreq/5000 + cnt)   '<- Your not thinking 3 dimensional here.  The FullDuplexSerial is running
                                 '   in it's own cog, and especially since the baud is relativly low, the three
                                '   'Ser' commands above have executed and loaded the TX buffer within the
                                '   FullDuplexSerial before all of the data has been sent.  So.... you must
                                '   wait a longer time interval so the data has a chance to be sent.
  waitcnt(clkfreq/40 + cnt)
                                '<- See OutA[TX]~ above ; remember the serial data is INVERTED, so this would
                                '   need to go LOW instead.
  waitcnt(clkfreq/5000 + cnt)   '<- This delay is ok because we are out of the serial stream ; this delay
                                '   represents the width of the pulse you want to send
  waitcnt(clkfreq/40 + cnt)     '<- This delay can be much shorter but is set the the same interval as the
                                '   entry delay above so that you can see in the attached scope image what
                                '   can happen with multi-processing.
'  Ser.Start(RX,TX,0,9600)      'restart serial ; don't do that! related reason to the Ser.stop note above.
1024 x 576 - 44K
    edited 2011-04-07 12:52
    Since you are running at 9600bps, bit-bang the output (even Spin should be able to do it) - problem solved
    or, use a separate "sync" pin, and then the slaves can waitpeq or waitpne on it after receiving the serial command
    edited 2011-04-07 12:54
    Bill Henning,
    "Since you are running at 9600bps, bit-bang the output (even Spin should be able to do it) - problem solved"
    - Right, that's what I would do, but this wasn't my project. Just helping out a friend.
    This still doesn't mean that the problem completely goes away at higher baud rates, so it's something we all should be aware of.
    edited 2011-04-07 13:15
    This is not a "Potential Gotcha with multi-core processing". This is a well known potential problem that can occur with any buffered I/O scheme. It can occur just as easily with a single core processor that does its serial I/O with an interrupt driven buffered I/O routine. It can occur with any single core processor with a double buffered UART, either on-chip or off-chip. If you need to know when a particular byte or byte sequence has been sent, you have to look at whether the buffer is empty yet and whether the transmit register has finished shifting out the last byte.
  • John AbshierJohn Abshier Posts: 1,116
    edited 2011-04-07 13:43
    I have had a similar problem:
    cognew(....
    do_something
    But do_something depended on a variable being set by the code running in the new cog. A short delay between cognew and and do_something solved the problem, but it took a lot of time to finally realize what the problem was.
    John Abshier
    edited 2011-04-07 14:04
    This is an excellent reason to add synchronous send to FullDuplexSerial etc. that does not return until the transmission is complete.
    or perhaps specify a LOCK or hub address the caller can wait on?
    edited 2011-04-07 16:07
    ...or just a tx_done method that returns true when no characters are pending or being transmitted.
    edited 2011-04-07 16:20
    i like the tx_done idea
    edited 2011-04-07 18:21
    Functions which return the number of characters waiting in the TX and RX buffers can be extremely useful, both for this reason and to prevent buffer overruns. In this case you'd wait until the TX buffer is empty before hijacking the output pin.
    edited 2011-04-07 18:30
    Waiting until the buffer is empty is not enough, since a character could still be in the process of transmitting. I agree that a tx_check method, which returns the number of empty transmit buffer spaces, would also be useful, but not for the same purpose that this thread addresses.
    edited 2011-04-07 18:36
    The character-off-chip issue came up before in this thread: [thread=129809]FullDuplexSerial Object - Detecting when data has been sent?[/thread].
  • davidsaundersdavidsaunders Posts: 1,559
    edited 2011-04-07 18:48
    Why would some one use serial to do this? Send a pulse, wait a short time and send the sync pulse.
    edited 2011-04-07 19:32
    davidsaunders,
    "Why would some one use serial to do this? Send a pulse, wait a short time and send the sync pulse." - The mechanism for intercommunication between Propellers is necessary to pass other information. Using the existing wires was an easy way to approach syncing the Propellers all together at once.
    edited 2011-04-07 20:31
    Here's a simple version of a transmit flush routine that I've used in some of my specialized FemtoBasic versions. It assumes that a just emptied buffer requires an 11 bit-time wait for the start bit, 8 data bits, and 2 stop bits to be shifted out. It's sort of a worst case delay. Ideally, the assembly transmit routine would copy its shift register to a hub memory location where this routine could check whether there are any more bits waiting to be shifted out. I didn't want to have to modify the assembly code to add this functionality. This does have to be added to the Spin part of FullDuplexSerial so it can access the buffer pointers and bit timing.
    PUB txflush
    '' Flush transmit buffer, then wait for last byte
    ''  to be sent.
      repeat until tx_tail == tx_head
      waitcnt(11*bit_ticks + cnt)
    Beau,
    Phew, I thought you were about to announce the discovery of a horrible bug in the Propeller chip.
    No, this is just a common or garden race condition that could happen with a single core chip and some external hardware performing the action you have forgotten to wait (or check for) the for completion of.
    Perhaps the title of this thread should be changed.
