feedback requested: Sigma Delta Tutorial for public review
Oldbitcollector (Jeff)
Linked is a complementary document to the ADC tutorial I posted a couple weeks ago.
I'd love feedback, comments, etc -- It's targeted an introductory level again.
http://dl.dropbox.com/u/7557533/temp/Sigma%20Delta%20for%20Public%20Review.pdf
Thanks in advance
OBC
Thanks in advance
OBC
I've never used the SigmaDelta object, but your example doesn't look right. Your code is The SigmaDelta method consists of a single line that starts a PASM routine. The PASM routine updates a long in hub RAM based on the pointer that is passed through the SigmaDelta call. Your code starts a new cog each time it loops. It seems like SigmaDelta should be called once before entering the loop. If you want every sample the loop should contain a waitcnt that matches the one in the PASM code. Of course, that would be a bit fast to print out to a serial port.
Dave
I've intentionally omitted the waitcnt for simplicity's sake, however I see what you mean by the routine launching a new cog each pass. I'll adjust it accordingly. Thanks
Edit: Document updated
OBC
