Sensors reading — Parallax Forums
Sensors reading
ben88ben88 Posts: 2
edited 2011-04-06 08:27 in BASIC Stamp
Hi
I'm using the BS2P40 chip.
I'm wondering if it is possible to do multiple functions like reading the sensors and running the main programming code at the same time?
thanks.
    edited 2011-04-06 04:54
    Welcome to the forum
    No ALL Basic Stamps can only do one thing at a time
    If you need to this then the Propeller is what you need to use
    ben88: It is true that the Stamps can only do one thing at a time. But since they execute thousands of instructions per second, it is possible to write your program so that several things happen sequentially in a very fast loop. Takes a bit of patience and discipline, but it's very possible and well-documented. For many applications this is fine. For true multi-tasking, the Propeller is the answer.
