Boe-bot shortest route
Hello I have a project with the Boe-bot where i want to make it drive through an entire line following maze with dead ends and continue until it reaches the end of the maze on the first run. Then It will make a 2nd run this time memorizing the entire maze and taking the shortest route to the end of the maze avoiding dead ends. I am using parallax's infrared line follower kit. Can any of you guys help me with the p-basic coding. I'm new to basic coding and am having trouble with this. Thanks
here is my code so far, for now it just followers the maze.
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
SELECT INL ' Select line follower states
CASE %11000000, %11100000 ' Pivot right
PULSOUT 13, 650
PULSOUT 12, 650
CASE %01100000, %01110000 ' Curve right
PULSOUT 13, 700
PULSOUT 12, 650
CASE %00110000 ' Slight right
PULSOUT 13, 750
PULSOUT 12, 650
CASE %00111000 ' Adjust right
PULSOUT 13, 800
PULSOUT 12, 650
CASE %00011000 ' Straight
PULSOUT 13, 850
PULSOUT 12, 650
CASE %00011100 ' Adjust left
PULSOUT 13, 850
PULSOUT 12, 700
CASE %00001100 ' Slight left
PULSOUT 13, 850
PULSOUT 12, 750
CASE %00000110, %00001110 ' Curve left
PULSOUT 13, 850
PULSOUT 12, 800
CASE %00000011, %00000111 ' Pivot left
PULSOUT 13, 850
PULSOUT 12, 850
ENDSELECT
LOOP
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
PULSOUT 13, 650
PULSOUT 12, 650
PULSOUT 13, 700
PULSOUT 12, 650
PULSOUT 13, 750
PULSOUT 12, 650
PULSOUT 13, 800
PULSOUT 12, 650
PULSOUT 13, 850
PULSOUT 12, 650
PULSOUT 13, 850
PULSOUT 12, 700
PULSOUT 13, 850
PULSOUT 12, 750
PULSOUT 13, 850
PULSOUT 12, 800
PULSOUT 13, 850
PULSOUT 12, 850
ENDSELECT
LOOP
