I found some 3 volt switching power supply @ 5 amps I need some circuit help
Controlling them with a Basic Stamp
I want build a Supper Bright LED Light
I am thinking about using about 200 LED running at 15 milliamps at 3/4 power
What would way be the best way to do this
http://www.mpja.com/prodinfo.asp?number=18557+PS
"MFG: AULT"
"P/N: MW125RA0303B01
Input: 100-240VAC 50-60Hz
Output: 3VDC @ 5A
Specifications/Features:
Wall mount switching supply. Non-polarized 2 blade input, 6ft. ZIP cord with 10mm long X 5.5/2.5mm coaxial power plug Center +. ULus/canada/TUV/CE listed.
L: 3-7/8" W: 2-1/2" T: 1-5/8" WT: .78"
A while back I tryed a UN2803 with a 3.3 voltage regulator But this did not work the way I want I know I could use a relay but I am not really liking this idea to much
http://forums.parallax.com/showthread.php?117491-Using-a-3-Volt-power-supply-to-power-LEDs-with-a-2N3904-will-this-work-lower-do
Output: 3VDC @ 5A
[ 3V leaves out Blues and Whites (their V_f > 3V), from my P-O-V. ]
What about switch the incoming power to the power supply with a soild state relay
Do you think would work
Has any one found a way to change the output voltage on these switching power supply
I have open a few switching power supply and they do not have any part # on these IC chips that are used
IF yes please share thanks
You instead start with 12-24v and put LEDs in series
Final step is a LED driver that controlls the current so they last years.
TPS61195
http://www.ti.com/lit/gpn/tps61195
if you need individual control of each led
http://focus.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=tlc59116&fileType=pdf
I am not sure which one I want to use
Around here? If only.
Anyway, Sam, I hope you didn't buy many.
You could do a super-red or super-green or some combination,
but you'll need to buy some resistors and transistors.
If you do this you must BE VERY CAREFUL. Working with line voltage can be hazardous.
I thought about doing it that way BUT Working with line voltage can be hazardous this the killer part of it that is why I do not want to that way
Yea If only I had allot of money Then I could really play with some real toys but that another story
I only bought 3 of them
If I used red one then who know what warning displays I could come up with
I might use some orange ones with these power supplys
I have some orange LED board that have three LEDs on them I would have to rework them to work that way
Do you need to have indivdual on/off controll of each led?
Do you need them to be on a long string (buy led christmas lights)
Or as a panel buy this.
http://www.amazon.com/WHITE-LED-Aquarium-Light-2501WH/dp/tech-data/B001NDU9XG
