Product Improvement
I'm currently working on a spinneret project and it involves two propellers talking with each other. While I work between them, I'm continually having to unplug one usb cable and then plug in the other so I can make changes to or monitor the output ( on the serial terminal ). It would be nice if we could have multiple instances of the propeller tool and the serial terminal running at the same time each pointed to their specific com port so I could stop switching my usb cable back and forth. It would also have the added benefit of eliminating me compile and run my spinneret code on the wrong prop resulting in some really interesting errors on the serial terminal.
2. Uncheck the box for "Associated files launch into single editor."
3. Close and restart the IDE for the new setting to go into effect.
Robert
