sumobot qti sensor help — Parallax Forums
aaz707aaz707 Posts: 8
edited 2012-06-25 06:44 in Robotics
I seem to be having problems with my sensors they work just not quick enough. When the sensors get to the white line there is a delay it tries to back up but the bot runs off the side. I am using the exact code from the manual copy and pasted from the pdf. I cant seem to figure out how to make the response time of the qti's faster. any suggestions . Thanks
  • dandreaedandreae Posts: 1,375
    edited 2011-04-01 07:36
    Sometimes the lighting can play a factor with the QTI sensors. Are you able to experiment with it under different lighting conditions?
    Dave
  • alex trebekalex trebek Posts: 1
    edited 2012-06-25 06:24
    I am having this same issue. The sensors are working, but by the time they start to have the wheels move the bot is already out of bounds. The arena is built to the rules specifications, and I have tried it under different lighting. It seems to make no difference what light it is under.
    Was there ever a solution to this issue?
    Can you guys both post videos to see what the problem is? If it really is the same problem, there may be an issue with the code or sensor location we can help with.
