Firefighting Compettition
My partner and I are entering the Firefighting Competition using the Boe-Bot. We plan to use the MLX90614 Infrared Thermometer as our main sensor to locate the flame (a small lit candle) however we are new to the sensor and need help with programing a 'roaming with' code, any help will be greatly appreciated.
It looks like there's an object for this sensor in the Propeller OBEX.
http://obex.parallax.com/objects/613/
Also, there's some product info and example codes on this page:
http://www.parallax.com/Store/Sensors/TemperatureHumidity/tabid/174/ProductID/520/List/0/Default.aspx?SortField=ProductName,ProductName
I've never used it, but perhaps it can give you some ideas.
Welcome to the forum! Before you get too far in your planning, please be sure to read the following two threads and follow the links therein:
http://forums.parallax.com/showthread.php?107565
spin is a language that Propeller chips use. You can download the free software for working with it here:
http://www.parallax.com/ProductInfo/Microcontrollers/PropellerGeneralInformation/PropellerMediaPage/tabid/832/Default.aspx
On that page, there is also a link to software that allows you to work with SPIN on a Mac, etc.
Oops. Sorry.
