Is there an asynchronous longmove?
I one is doing double-buffering how could one implement and an asynchronous longmove in spin/pasm?
like about 480 longs?
DAT
org 0
AMOVE cogid me
mov tempt,par
rdlong source,par
add tempt,#4
rdlong destination,par
add tempt,#4
rdlong moving,tempt
aloop rdlong source,tempt
add source,#4
wrlong destination,tempt
add destination,#4
djnz moving,tempt
cogstop me
me res 1
tempt res 1
source res 1
destination res 1
moving res 1
You could dedicate a cog to moving longs around. It would check some hub locations for source and destination addresses and a count of the longs to be moved. You'd set the count to a non-zero value to start the copy operation and the move cog would zero the count when it was done. That would reduce the latency (for startup) considerably since the move cog would continue running, checking the count regularly.
