Propeller Proto board voltage regulators
The Propeller Proto USB board is marked 6-9 VDC. The manufactures data sheet says the maximum input voltage for the LM1086 is 30 volts. I am useing the board in an automotive/heavy equipment application with 12 and 24 volt systems. Is it safe for me to apply these voltages to the Proto board?
Additionally, I do not use any of the servo outputs for this application.
DirtJockey
DirtJockey
DirtJockey
Also, you can use this calculator to come up with the proper resistors for your desired output...
http://www.electronics-lab.com/articles/LM317/
Or this one...
http://www.whatcircuits.com/lm317-calculator-v2/
Thank you for your help, I often forget to consider heat and power disapation.
DirtJockey
