(OT) Math Puzzle (from Bean in 2005)
doggiedoc
Bean you never gave the answer:
Original Post here.
Paul
This one is not a trick, it will make you think though.
A man is floating in a boat in a pool. There is also a large stone in the boat.
The man pushes the stone out of the boat and the stone sinks to the bottom of the pool.
Does the water level in the pool go up, down or stay the same (as when the stone was in the boat).
See if you can figure it out BEFORE you google it...
Bean.
Original Post here.
Paul
But if you like a good math problem and similar triangles, try http://en.wikipedia.org/wiki/Crossed_Ladders_Problem
Yes, the level would go down.
If the guy stood up and peed over the side would the water level change? LoL
(might this be very slightly dependent upon the temp of the water vs the pee?)
There is a farmer in China claiming one of his sheep gave
birth to a puppy :-)
Anyways...I only became a moderator because I am
often on the forum when many in the US are asleep.
So I can delete those spam Viagara posts in the WEE hours....LoL
* See XKCD http://xkcd.com/356/
That's no big deal. My aunt has had a sheepdog for years.
You mean how do you discern which is the liar and which is truthful?
You could ask either of them any question where the answer is
obvious.
Are you a man?
Is that a ladder?
Is the sky blue?
I have to be missing something here???
I looked at that ladder question, it made my head hurt.
Now my head hurts again.
Good one Phil!
Another good one!!
Thanks to Phil..
If the man is dead floating in a sunk boat then there is nobody to move the rock... the water level stays the same. :-)
I never get headaches any more, my OCD meds killed them off.
That question and similar brain teasers give me a pain no medication
could stop....well, perhaps a roofie might ;-)
@Beau Schwabe
You are thinking far afield! Angling way way out there on obscure tangents.
I bet you play chess huh? I gave up chess, it brings on those head
pains too...LoL All I play now is practical jokes.... I'm the queen of
practical jokes.... the funny stories I could relate :-)
Excellent point Beau! I think Bean needs to clarify the question!
Paul
What if the pool was floating inside a bigger pool. Would the water level change in the bigger pool ?
Bean
or more in some cases.
Maybe check the local Surf Report too.. thats allways a good idea anyway before starting a major project...
"You are thinking far afield! Angling way way out there on obscure tangents." - Just keeping true to my style :-)
"I bet you play chess huh?" - Poker instead
Bean,
"You are such a trouble-maker..." - I wouldn't have it any other way :-)
"What if the pool was floating inside a bigger pool. Would the water level change in the bigger pool ?" - A pool floating on another pool ... sounds like oil and water ... no, the bigger pool in this case would not change it's level.
On the first problem though... it boils down to displacement by weight verses displacement by volume. If the rock is in the boat (assuming that the boat IS floating) the water is displaced by weight, but by being in the boat the weight is dispersed evenly across the area of the boat in contact with the water.... As far as it's concerned, the water "sees' the man+boat+rock as a lower density object than itself so all of it floats within the boat. If the rock is thrown over, then depending on the size of the rock, the the volume will displace the water a certain amount, The question is, Is the displacement by weight (man+boat) greater or less than the displacement by volume of just the rock in the water. If the volume is greater, then the water level will go up, if the displacement by weight is greater, the water level will go down. If they are equal then there will be no change.
For this problem, I don't think there is enough information, since the effective weight displacement can be governed by the size of the boat, and density of the rock.
You my head hurt this to funny to think about
You are both making my head hurt even more
Beau Schwabe
1 six inch plastic bowl filled 1/2 way with water = Pool
ALTOIDS Box (remove lid) = Boat
1/4 1/3 measuring cup = Man
10 marbles = rock used in test #1
15 quarters = rock used in test #2
Electrical tape = used to mark the levels on the plastic bowl ... and cover the holes on the ALTIODS Box where the lid attached.
Note: The 1/4 1/3 measuring cup was to keep the center of weight in the 'boat', otherwise the marbles would roll to one corner and sink the boat.
